proporsche's Avatar
as i said remove the yellow cover-it has no importance..you can always get new one..turn you idle screw 1/2 a turn in..that will take care of your problem..do need to mess with the c/o adjustments unless you can see it in the smog scale machine...again enjoy it and drive it...if you lube it it will run as you can see on my 911 it has over 494K miles............
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 04-21-2020, 12:12 PM
