Shift rod coupling pin stuck
I have been trying to beat the pin out of the coupler for a good 20 min and it wont budge. Ive seen videos where guys just knock these things out. What am I doing wrong?
Old 04-18-2020, 07:37 PM
Old 04-18-2020, 07:38 PM
I discovered mine has a pin that needs to be removed
Old 04-18-2020, 07:52 PM
Clamp the steel part in a vise first, then hammer and a drift, or use an air hammer gently.
206 637 4071
Old 04-18-2020, 08:37 PM
I got it out. Turns out there was a pin in the middle for some reason. All the other threads I read and videos I watched never showed a pin.
Old 04-18-2020, 09:40 PM
Old 04-18-2020, 09:41 PM
cycling has-been
bkreigsr's Avatar
People will do that to the pin when they have experienced a pin drop out of the assembly.
I went a different route, and had a machine shop drill a hole lengthwise so I could tie it off around the coupler with safety wire.
This pin came with three equally-spaced groves around the outside. When they wear away, or are in my case, are sanded down, the pin will drop out.
Bill K
Old 04-19-2020, 06:57 AM
