echrisconnor's Avatar
How interchangeable are steering wheels between models?
I'm curious how different the 1960's - 1980's steering wheels are. If I want to put a 911 steering wheel in a 914, or a 944 steeting wheel in a 911. Basically, are the mounts all the same, or how do they differ?
'76 911 Carrera 3.0
Old 04-29-2003, 02:08 PM
Ray 911s's Avatar
Steering wheel interchange
Here's a rough break-down:
These models are all interchangeable as far as splines go:
914/6 up to 1971, 356 from 1958 to 1965, 911 up to June 1974
These models interchange with each other, but not the group above:
944 from 1985 1/2, 951 between 1986 and 1989, 911C2, 911C4, 911RS from 1989 to 1994
These models are interchangeable spline fits, but not with any other groups:
911 after July 1974, 930, 911 Carrera
The following splines are not interchangeable with any other cars even within this group:
914 up to 1971, 914 up from 1972 to 1976.
I hope that's clear. If you have a specific interchange in mind, let me know. I'll check it out.
1977 911S
1973 Alfa Romeo GT Veloce
1997 Lotus Turbo Esprit V8
2016 AMG C63S
Old 04-29-2003, 02:22 PM
Wow. OK, so the early 911 really isn't interchangeable with any other car. The pre '74 914/4 may work, but does this require using some sort of adapter ring? Is that what the rear hub cover is?
Anything from a 944/24/51 may interchange with each other or, the later C2s etc., but not with any other 911's.
'76 911 Carrera 3.0
Old 04-29-2003, 02:42 PM
Harlan Chinn's Avatar
Very Impressive Ray. Good information for a compatibility matrix.
Harlan Chinn
Pacific Northwest Region
1998 Carrera S ArcticSilverMetallic
1982 911SC PazificBlauMetallic
Old 04-29-2003, 04:31 PM
As far as I was aware, only the 914/6 wheel has the same splines as the early 911. This was the steering wheel that was used on the 73 RS.
380 mm dia instead of the std 400 mm. Have one on my 72S. Looks std until you're behind the wheel, then vive la difference!
Kiwi
Reg # 381
1959 356A Conv D
1967 912
1972 911S
Old 04-29-2003, 09:41 PM
Send a message via ICQ to AirJose
Sorry to bring this old thread but It did not clarify my question...
What other Porsche smaller steering wheels will fit my '69 912? Mine is too large!!!
Thanks,
Jose
Old 09-18-2020, 08:44 AM
