rennline bumper shocks?
Hi gents
Can someone confirm that the rennline bumper shocks offer the same weight savings (approx) as the euro ones. Looking to save weight by replacing the US spec shocks. Is it worth doing front and rear? These rennline shocks are much cheaper than the euro units?? Thanks in advance |
A bumper shock's purpose is to raise the spring rate at full bump. Personally, I'd look for bumper shocks that fit suspension design / spring rate around the intended use of the car (significantly lowered / track car) rather than to lower weight. Koni designed them for race cars many decades ago, and (AFAIK) they still make them in different effective spring rates. I've used them on my formula cars.
Current: 914/6 GT Conversion, Cayman Old: Many PCars + Formula Racecars |
I believe the OP is referring to the shocks/tubes in the actual bumpers.
Ass-engine Nazi slot car -- PJ O'Rourke |
Registered Minimalist
When you say "euro units" do you mean Porsche brand euro crush tubes? I can't answer whether they are the same weight as the official Porsche tube. I don't see how they could possibly weigh much more as the Rennline units are extremely light and well built. I bought both the front and rear impact tubes. The difference in the crush tube vs the hydraulic US impact tube is dramatic.
One thing I noticed was that on my car, I had to drill the ends out of the impact tube mount on the car. Both ends of the Euro tubes are larger thread. The bumper side studs will fit through the bumper, but you need new hardware as the studs are larger. As I mentioned, the chassis end of the tube mounts on the car need to be drilled out larger to accommodate the larger crush tube stud and you will need new washers and lock-nuts.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads Last edited by 75 911s; 05-16-2018 at 08:31 AM.. |
I recently replaced MY84 rear impact bumber shocks with the Rennline units - spoke to Rennline about weight of their units (approx 1lb each) before ordering. I do not know what the Euro versions weigh but if steel constructed then should be about the weight as RL. I did not weigh the RLs before install but are considerably lighter than OEMs. I’ll try to weigh the OEMs and post. Additionally, I had no fitment issues as it was plug and play on my install
If you give your word: keep it. |
![]() You can see the other end in the shock above. The rennline bumper through studs are m10 vs m8 on the us hydrualic shocks. I guess they went bigger for the SC and carrera? I always thought the shocks were all the same.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
(man/dude)
I bought a complete set of these for my lightweight 3.2 Carrera project - havent fit them yet but did compare them to the stock units from an 85:
Rear bumper shocks: ![]() ![]() Note the studs on the two sets do match in size. The weight savings isn't huge, but I for one want to maintain some semblance of bumper integrity on my car - no fiberglass for me! So every pound counts. I briefly considered going with a fiberglass bumper blade but the stock one is very strong for it's weight - only 16 pounds. Don't believe the fiberglass suppliers claimof "Saves 18 pounds!".
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 Last edited by Jonny042; 05-16-2018 at 05:08 PM.. |
Thanks gents
Ive just realised these are a crush tube? so not a shock as such. Any impact is a one time use for these...?? I think Ill order 4 |
... someone drilled holes in the tubes...
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
Titanium User
I get close to 9lbs for the front shocks. So if the Rennline are 1lb each, then by my calculations that's roughly 7lb savings for just the front end.
Duane
Helpful as always mate Thanks all. I'm heading to the US next month (from Oz) and I plan on stuffing my suitcase with as much gear as I can!! |
Can you explain? 6lbs seems low for oem bumper shocks. Are you saying these 6lb shocks were drilled out to make them lighter? I thought oem us shocks were more like 9lbs. Thanks!
1981 Euro SC (3.2L) )(foolishly sold); 2004 911 GT3; 2008 430 Scuderia (65k miles!); e36 M3 manual coupe; 2019 Range Rover Sport V8 supercharged (wife's ride) |
(man/dude)
I think maybe he was suggesting it could be done to lighten the rennline/euro mounts even more.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
This is my plan. Drill a hole in each of the front shocks, empty out the fluid, compress them, set screw to keep them where I want them, modify bumper and/or accordions, swap the stock SC smile for one from a 964.
I've seen a few bumper tuck threads and while not as prevalent among 911 owners as it is with the E30 crowd I think it looks good.
_______________________________ 1982 911 SC 240,000mi and counting |
Guest
Posts: n/a
Porsche Addict
Doesn't anyone just make a replacement aluminum bar? Hollow?
Super lightweight? No shock needed for track cars. |
Don't know why they call these shocks
they are steel crush struts that the bumpers mount on that is why they are so light
Administrator
I swear I saw at some point some company who made aluminum crush tubes, but Google Fu fails me now. Don't think aluminum saved a notable amount over the Euro crash tubes.
Matt - 84 Carrera |
