Using MSD Digital Programmable 6AL-2 Twin Plug Distributor
Hi folks,
I'm new to this forum and we are re-building s 911 T models from '71 to a 2.5 ST version incl. engine upgrade (66mm stroke, 89mm bore, 10.5:1 compression, max. 8500 rpms).
As we would like to have at higher revs also higher ignition advance timing than 28 or 30 degrees I was thinking to use 2x MSD programmable ignition box 6AL-2 to hook up on a twin plug distributor system.
For this reason I'm asking if anybody has some experience and which inductive (contact-less) twin plug distributor can be recommended for this application with no advance curve or deactivated centrifugal advance timing to use this external ignition trigger system.
Inputs or other suggestions highly welcome. Stay safe and best regards from Switzerland
Old 04-23-2020, 03:05 PM
