Brembo 3.0in calipers
I picked up a pair of the Brembo 3.0 in calipers. I'm hoping to use these for my rear brakes. These currently have steel pistons. I want to replace with aluminum piston but there don't appear to be any available. The 48mm pistons are not compatible with these Brembo calipers.
There is a very small step (1.0mm ?) on the face of the piston but I'm sure what the purpose is or the science behind this feature. Looking forward to input from the experts Thanks David |
I have circled the feature that I'm inquiring about
this "step" is reasoned for angled pressure application on the pad.
when re-installing piston in caliper you must respect the position please do a search, this has been outlined here many times. here's a quote from Bill after a very quick search:
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit Last edited by Flojo; 04-27-2020 at 06:29 AM.. |
Here is my rough draft of my step file for my cad
So it looks like I simply need a certain amount of surface area on the leading edge. Something over 50%
Under the radar
So, how are you going to make this?
What alloy of aluminum? What surface treatment will you apply? Why not use stainless?
The best material for the pistons would have a low thermal transfer coefficient
Ti is best SS next best followed by steel there are some really, really high end ones made either from ceramic or w/ ceramic buttons
Bill, I was hoping you would post on this. Why not aluminum, same rate of thermal expansion as the caliper? Titanium would be neat but I'm under the impression that the rate of thermal expansion is less and the goal was to have the caliper & piston grow at the same rate. I was planning on using aluminum because that is what I have in my "S" calipers.
Gordon, I was planning on hard coating the aluminum pistons. Do I need grade 5 or will grade 2 suffice. I will ask my machine shop if they can machine titanium. Last edited by Harpo; 04-27-2020 at 09:30 AM.. |
Stainless has low thermal conductivity but fairly high thermal expansion.
Sent from my Nokia 7.1 using Tapatalk |
No plans to race this car. Do you have a source for Ti or ceramic pistons?
Thanks David |
Porsche Motorsport
