I've had a throttle stick open on me twice, and it certainly gets your attention. On my 911, it was because the throttle and clutch cables were twisted (I had recently replaced the clutch cable) and the clevis on the clutch cable was hitting something. On my SE-R, I had left the positive battery terminal cover on top of the engine by accident and it bounced its way into the throttle mechanism. Oops!
'80 SC Targa
Avondale, Chicago, IL
Old 01-02-2024, 12:54 PM
Originally Posted by SoCalSK8r View Post
This same thing happened to me…and almost Sht my pants too.
I was heading back from a C&C in Malibu with my 10 year old son… mashed it coming into Tunnel 2 on Kanan Road and the pedal got stuck….. I was able to shut off the car, pop it into neutral and get over to a safe spot on the side of the road to get it fixed.
If that had happened to me out on a smaller canyon road, or worse yet coming into a tight turn, it would have been a disaster. This situation really made me think….
Anyway, glad you weren’t hurt. This thread should be a sticky on the page so newer owners have awareness of this potential hazard. I wasn’t aware that so many others have had this happen to them as well.
I shifted to neutral, car bounced off the rev limiter twice, turned off the engine and coasted to the shoulder. all in a matter of 5-10 seconds.
thank god I was able to do that. the right lane was actually busy too. can't imagine what i would do if there was no shoulder..
1987 Porsche Carrera Coupe
Old 01-02-2024, 06:04 PM
Grappler
Rodsrsr's Avatar
I tend to agree. I would trim back the metal on the bulkhead area, and rebuild the cluster on any early 911.
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 01-02-2024, 06:36 PM
ahead of the curve
Jeff Burger's Avatar
I realize this is an old post recently brought up again but I will post this for future reference.
If the bushings are ok another cause of this can be the little arm getting bent. this is caused by the gas pedal not reaching the gas pedal stop before the throttle rod hits the throttle stop at the intake. As you mash the throttle the top of the throttle arm bends because the middle cant travel any further as it is restricted at the mid-point by the throttle rod.
Get someone to watch the throttle stop while you fully press the gas pedal. the throttle should not actually hit the stop. This is a pretty easy check every one can do to prevent a pretty scary and dangerous event.
IIRC the pedal board has the stop so if you were driving without it that also could have contributed to torquing the arm.
19 Carrera T - MPS member
92 C2 SR coupe M491/ 3.8 look- manual
92 C2 SR coupe cobolt blue- manual
73 914 1.7 (?) AG -a solid project looking 4 a sugar daddy
73.5 T gemini blue SR coupe sold 8/22 my last long hood gone
Old 01-03-2024, 09:55 AM
