Voltage Regulator issue
Hi
I changed the voltage regulator on my 1984 911.
Drove it a few times and all ok
Noticed Voltage jumping up to 15.1 and then back in spec then down to 12. It Revs do not influence the reading.
I think I have a faulty voltage regulator but asking if it could be anything else
geoff
Old 04-28-2020, 09:32 PM
Just to be clear, you changed your VR because of what? Is the problem with the new one the same as with the old one?
Old 04-28-2020, 11:32 PM
Check the grounds
1973.5 911T ——-1974 914/1.8
Old 04-29-2020, 12:29 AM
yes... same problem as before I changed the regulator.
The new one worked for a while.....
Old 04-29-2020, 02:47 AM
Under the radar
Trackrash's Avatar
Originally Posted by Artfrombama View Post
Check the grounds
And all the connections between the alternator and regulator, especially the black and blue wires.
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-29-2020, 09:52 AM
John W
Sounds like an intermittent connection. Check the ground strap between tranny and engine first. Then clean up all the alternator ones. I recently polished up all mine when I had a similar Issue. Good luck.
Old 04-29-2020, 01:14 PM
proporsche's Avatar
This.....
1985 911 with original 502 191 miles...808 198 km
Old 04-29-2020, 02:10 PM
thankyou
I will give it a go this weekend
Old 04-29-2020, 05:41 PM
