rickeolis's Avatar
Porsche Crest 2.7'S' carb'd engine output?
Hi Pelicanites,
This is the engine I am getting from K9Handler (Smitty), my question is, I have read Bruce Anderson's manual that says this engine has 175HP, where the stock 911 (non 'S') has 155. If I take it and put SSI's and the carbs off of my '69 how much HP should I expect? No other changes.
The car is a 1975 model 911S (Built Dec 1974).
The engine is the original 911S powerplant....same engine in the Carerra that year as well.
-Rickeolis-
1986 Corvette
Old 04-10-2003, 03:22 PM
JTO JTO is offline
Based on my little experience, I'd say about 185.
Troy
Troy
Past: 1975 911S Silver Anniversary-rebuilt and sublime.
Past: 1988 Carrera-backdated with a 3.6 and all the goodies.
Present: 2011 GMC 2500HD with the 6.0 & 4x4!, 2004 Toyota Sequoia (wife's)
Old 04-10-2003, 03:55 PM
If you're not changing the cams/compression on the 8.5 compression 2.7 engine, is there any advantage to carbs over stock CIS?
Is CIS not included with the engine you're getting?
1977 911S Targa 2.7
Old 04-10-2003, 04:03 PM
rickeolis's Avatar
Porsche Crest
David, according to Bruce's 911 handbook there is, though probably not tons more HP, just a better breathing engine throughout the powerband. Yes the CIS is on the motor, and I am also considering keeping it.
Troy, are you running this similar setup? I would guess about the same, 185HP, which would be nice.
Anybody else running this configuration? I did forget to mention the Pertronix Ignitor and Carrera hydraulic cam chain upgrade that Smitty already has on the motor-
-Rickeolis-
1986 Corvette
Old 04-10-2003, 04:13 PM
JTO JTO is offline
rickeolis,
I have a fully rebuilt 1975 S engine. My modifications are mainly for durability (APR, timecerts) a mild CR increase, polished intake runners and heads, SSIs with a GHL muffler. A couple of people have suggested that my engine is making about 195 HP, mainly due to the exhaust modifications.
I was thinking that you might not gain much HP with carbs due to the CIS cams. I don't know the condition of the engine either, so I was trying to be conservative, but really, I can only guess!
My car is quite fast, and has dusted a fellow PCA guy's SC and a Mustang GT. I wish it had another fifty HP though!! Hee Hee. Now I'm wishing I did what Howard has done to his 911S- a 3.6, for probably the same money!
Troy
Troy
Old 04-10-2003, 04:22 PM
rickeolis's Avatar
Porsche Crest
Well, it was completey rebuilt about 4000 miles ago, and I have driven the car when that engine was still in it, and it ran like new car.
My current motor is the stock '69 'T' engine (tired) putting out a whopping 110HP, (on a good day) so the new one at a theoretic 185 HP should hall a$$. I have been lightening the car up, and am still in the process of replacing the suspension pan, and front bushings, struts, etc.
Troy, when you say mild compression upgrade, what do you mean?
Does anyone have experience with water injection in this style setup? (carbs) It's supposed to help cool the engine, as well as increase the compression slightly...
-Rickeolis-
1986 Corvette
Old 04-11-2003, 07:50 AM
Rouxzy's Avatar
You won't gain a whole lot, if anything with the carbs without changing the cis pistons and doing something different with the cams. The cis pistons and cams were built for emissions not power.
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip
One Way To Get More Horsepower Is To Get A Bigger Horse!
"I couldn't find the sports car of my dreams, so I built it myself"
Ferdinand Porsche
Old 04-11-2003, 05:18 PM
Randy Webb's Avatar
You WILL gain a whole lot of fun and engine responsiveness, tho maybe not hp. I have 2 cars wtih 2.7's in them one with Carbs & SSI, the other with stock CIS and SSI. The difference is night and day. You will be very happy, tho new cams and pistons will make you much happier.
Old 04-11-2003, 05:31 PM
JTO JTO is offline
rickeolis,
I flycut the heads and am at about 9.0:1 on the CR.
Troy
Troy
Old 04-11-2003, 05:52 PM
rickeolis's Avatar
Porsche Crest Can't wait!
Randy, Troy, thanks, the engine is on it's way, and I can't wait. I did some work on the car today, and I see some things that I should beef up for the new HP! Later-
-Rickeolis-
1986 Corvette
Old 04-13-2003, 04:28 PM
Cool
if K9 installed new pistons["completely rebuilt"].. I see no reason to install CIS pistons.. maybe you already have 2.7 RS pistons.. they're cheap enough........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-13-2003, 04:42 PM
rickeolis's Avatar
Porsche Crest
Yeah, I'd sure like to know... He (K9) said that he bought the car right after the P.O. had the rebuild. The guy was a good friend of his, and he gave him a copy of the receipts, but K9 does not know everything that was done specifically. He gave me the name of the shop where it was done. I have not tried to contact them as of yet.
Thanks for the heads up!
-Rickeolis-
1986 Corvette
Old 04-13-2003, 05:00 PM
