DG BG... which sensor is which?
The cables of my 3.2 flywheel sensors are labeled DG and BG. One detects engine speed and the other timing, right? Well, I need to put these things back on the engine the correct way. So which is which? And in what position on that little sensor mount do they go? Which one goes on the top? Which one on the bottom?
Thanks,
~Hugh
'84 Carrera
Old 12-18-2002, 10:33 AM
GFCC
Jeff's Avatar
Hugh,
DG is the Speed Sensor
Bg is the Reference Sensor
I believe the Speed Sensor goes in the middle and the Reference sensor goes on bottom, but it shouldn't matter as long as you match like wires (DG to DG and BG toBG).
Jeff
1976 911 Coupe w/ Euro 3.0 - Sold
1987 Carrera Coupe - Sold
1999 Carrera Cabriolet - Current
Old 12-18-2002, 11:47 AM
the speed sensor, DG, is mounted above the reference sensor on the flywheel mount and above the BG on the wire plug mount.
206 637 4071
Old 12-18-2002, 01:13 PM
GFCC
Jeff's Avatar
Yep, What JW said. I miss read your post. I thought you were talking about the connections in the engine bay. Just goes to show you shouldn't post without being fully cafinated.
Jeff
Old 12-18-2002, 02:40 PM
Thanks guys! One more piece of the puzzle comes together.
Cheers,
~Hugh
'84 Carrera
Old 12-18-2002, 03:01 PM
18 years on I am in this same re-build boat - bought a 3.2 motor in pieces and in the final assembly stages. It sure looks to me like the speed sensor (the one closest to the small teeth on the flywheel if I'm correct) sites below the reference sensor. It sits farther outward, but in the vertical direction is the bottom one. Just want to make sure I get the BG and DG connectors hooked to the right sensors.
Thanks!
Bill
Old 05-02-2020, 01:26 PM
DG is the lower sensor and the center plug, in spite of my '02 post. dyslexia?
206 637 4071
Old 05-02-2020, 01:36 PM
Thanks John, I had to check it three times as I really didn't want to question the expert :-)
I have another question on the injector harness wiring, posted in another old thread on the subject.
Bill
Old 05-02-2020, 03:31 PM
