DG BG... which sensor is which?
The cables of my 3.2 flywheel sensors are labeled DG and BG. One detects engine speed and the other timing, right? Well, I need to put these things back on the engine the correct way. So which is which? And in what position on that little sensor mount do they go? Which one goes on the top? Which one on the bottom?
Thanks,
~Hugh '84 Carrera |
GFCC
Hugh,
DG is the Speed Sensor Bg is the Reference Sensor I believe the Speed Sensor goes in the middle and the Reference sensor goes on bottom, but it shouldn't matter as long as you match like wires (DG to DG and BG toBG).
Jeff 1976 911 Coupe w/ Euro 3.0 - Sold 1987 Carrera Coupe - Sold 1999 Carrera Cabriolet - Current |
the speed sensor, DG, is mounted above the reference sensor on the flywheel mount and above the BG on the wire plug mount.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 12-18-2002 at 02:51 PM.. |
GFCC
Yep, What JW said. I miss read your post. I thought you were talking about the connections in the engine bay. Just goes to show you shouldn't post without being fully cafinated.
Thanks guys! One more piece of the puzzle comes together.
Cheers,
~Hugh '84 Carrera |
Thanks! Bill |
DG is the lower sensor and the center plug, in spite of my '02 post. dyslexia?
Thanks John, I had to check it three times as I really didn't want to question the expert :-)
I have another question on the injector harness wiring, posted in another old thread on the subject. Bill |
