-Wayne http://forums.pelicanparts.com/uploa...1590975316.jpg |
A flaky injector could easily be affected by heat which would help explain the 2 minute issue. One cylinder starts misfiring which then starts to throw other things off.
Doesn't sound too bad, hows it driving?
-Wayne |
-Wayne |
914-6
When the fuel rail was out, was it checked for rust? I got a 3.2 in a 914 that sat for 4 years, the "T" line to the side rails rusted almost to the point of being blocked. same crap in the return line to the tank.
Sorry, this is not really any help ...
But if you are looking for some help "beating the snot out of it on the highway", I might be up for a trip ;) |
-Wayne |
-Wayne |
If you go make sure you’ll have a full tank of gas and a blowup doll in the passenger seat. It’ll make for more drama when the news choppers try to decipher if your passenger is voluntarily or involuntarily joining the run..... |
Could be fodder for a new book. "101 Ways To Elude Police" by Wayne Dempsey.
Consider removing the firewall insulation for better airflow. Might run hot the way it is. Belt changes and timing checks would be easier, too.
I have a 3.2 that is perfectly smooth cold, idles a little rough warm, but smooths out again around 1500 rpm.
I've now found several small vacuum leaks that two smoke tests didn't turn up. I see you don't have half the vacuum plumbing I have -- just to say that a cold smoke test at 1 psi is not that reliable. |
-Wayne |
-Wayne |
Searched this post but didn't see it in the results, did you ever do a system fuel volumetric test to see if any cylinders are being starved? e.g. measuring each injector output while installed in the rails on the engine to include the "system".
Thought is potentially having good pressure but marginal flow that actually shuts off or starves a cylinder when it drops off the warm up RPM. This is based on your observations of a left/right difference after the car kicks down. |
Am I the only one who finds it odd that cylinder 4 is running 30-40 degrees hotter than the other 5? When I get time I'm going to have to fire up my car and take some readings. I don't recall any of mine being that far apart.
Edit: You mention a few times early on that you measured temps and "they were all fairly even" (post 88, page 5). I haven't come across a post yet where you have temps. Just seems odd to me that the one is a good bit higher than the other five when the other five are all within 10 degrees. |
| All times are GMT -8. The time now is 05:00 AM. |
