Need some input -> Problem with 3.2 transplant going lean and misfiring after two min
Like John Walker a month or so ago, I've got a 3.2 Carrera engine that is giving me fits. I do think that these are probably the most difficult cars to work on because there are no codes or warnings or any real hints as to what the problem is. With most mechanics, you start swapping in and out parts to try to find the problem. Diagnosis with an oscilloscope is time consuming (compare to checking trouble codes on something like a Boxster), and the use of an oscilloscope is an art - if you don't use one all the time, it can be difficult to get it quickly dialed in.
Here's the story, it's a 914 with 3.2 transplant. I did not build this car, and when it arrived at my shop (with the 3.2 installed) it never ran correctly. This was 11 years ago (2009). The car sat for a long time (I was irritated with it and the fact that it didn't run properly). Then it was stolen, and disappeared for about two years. Then it was located, and found. I emptied the tank, changed the fuel filter, and started it up and it ran the same. The problem was a hunting idle. That issue is gone now, but another problem has shown up. Here is the issue: When you start the car up, it runs fine for about a minute or two. The idle goes up to about 1,100 or so. Smooth running, no misses. Air/fuel mixture is rich (haven't set that yet) and seems within range). Then, after about a minute or two, the idle drops down to about 850 or so (where I set it), and then the car goes lean (to about 18 or so air/fuel mixture) and starts missing. If you rev the engine just a little bit off of idle, the air.fuel mixture goes straight to 14.7 or so, but the car is still flubbing / missing at this point. Since the car runs perfectly fine for a minute or two and then all of a sudden starts to flub / misfire, it would seem to be a fuel injection problem for sure (not a mechanical or ignition problem). I replaced the plugs, cap, and rotor regardless because the car was stolen and sitting around for a long time, so who knows what happened to it, etc. It's also a transplant into a 914, so there are some unusual "modifications" that appear to be done to the car (it has two boots with some open ports sealed, etc.). It also has the thermo valve plugged up, and all of the evap stuff removed. It's got a sport muffler on it too, but since it runs fine for the first minute, I don't think the exhaust has anything to do with this issue. Here's what's been done so far: - Tested the air flow meter with an oscilloscope (no issues found) - Smoke tested the car for vacuum leaks when cold (found a very small leak which I fixed, but didn't fix the issue) - New plugs, cap and rotor - Jumpered the test plug and set the idle to be 800 rpm. - Checked each wire with oscilloscope and inductive sensor - Checked idle control valve -> clean and working fine - Checked the pulse to the idle control valve (both sides, looks normal) - Checked TDC sensor -> stumbles and shows odd signal when the car is misfiring (expected?) Appears to show okay when running just on the starter. - Fuel injectors - sent out to be cleaned and balanced. - Checked the injector operation (clicking on and off when powered) - New fuel filter. - Checked altitude sensor - Checked idle switch - Checked voltages - all okay - Checked the full throttle switch - okay To Do: - Check fuel pressure - Check temp control switch (this is plugged off - may be leaking when warm?) - Check the vacuum controled fuel pressure regulators (although they shouldn't theoretically change 1-2 min after starting the car). - Check intake air temp sensor? - Check cylinder head temp sensor (Temperature Sensor II) - Smoke test the car for leaks when it's warm not cold Thoughts: - It's not the O2 sensor since the problem is shown at idle, where the O2 sensor values are ignored. - Although I got some wavering results on the TDC sensor, I think that's a byproduct of the misfire, not causing the misfire, since running the car with the starter worked fine, and the car also runs perfectly fine for the first minute. Also, an intermittant TDC sensor shouldn't cause the lean condition at idle. - Not the DME relay, seems to be working fine. - Cylinder head temp sensor - if defective, the car wouldn't start. Again, the car runs great when cold - idles at 1,100 with a slightly rich mixture. Then after a minute or two, it drops down to 880 where the air-fuel ratio goes to about 18 and it starts missing and "flubbing" out the exhaust. By the way, I bought a really neat breakout box setup on eBay. It's an OTC 3525 breakout box (typically about $100 on eBay) with the Ford adapter 007-00055. Together these use the same connector as the BOSCH Motronic setup for the 3.2 Carrera. A factory "BOSCH" breakout box is near impossible to find, and when you do, they are about $600+. This is a cheap and effective solution. Let me know what the expert's thoughts are on this... Thx, Wayne Here's the car as we're working on it: http://forums.pelicanparts.com/uploa...1588489309.JPG Here's the setup in the trunk with the oscilliscope on the left, the breakout box on the right. I also have the Innovate tool with the O2 sensor shown here that allows me to check the mixture of the car. http://forums.pelicanparts.com/uploa...1588489309.JPG Here's the breakout box with the BOSCH pinouts labeled. I just saved someone about an hour's worth of work, if someone buys one of these on eBay: http://forums.pelicanparts.com/uploa...1588489309.jpg Oscilliscope pattern of the square-tooth wave pattern sent to the ICV (idle control valve): http://forums.pelicanparts.com/uploa...1588489309.jpg Another photo of the car: http://forums.pelicanparts.com/uploa...1588489309.JPG This shows the inductive sensor (got it with the Innovate tool) that you stick on the spark plug wires to check for consistent spark. Looks pretty good to me. You can also do this check with a simple timing light. http://forums.pelicanparts.com/uploa...1588489309.JPG I tested the air flow meter with the oscilliscope. Basically set it up for a slow trace and then pushed the flapper open and closed. No issues seen here: http://forums.pelicanparts.com/uploa...1588489309.jpg This was the signal from the rpm / speed sensor. I wasn't too sure about this one, I will take a closer look at what I think it's supposed to look like tomorrow. This and the top-dead-sensor readouts looked okay to me, but I want to double-check them: http://forums.pelicanparts.com/uploa...1588489506.jpg This is the TDC output: http://forums.pelicanparts.com/uploa...1588490064.PNG |
Here's a video showing a startup from semi-cold. As you can see, the car runs fairly well in the 40 seconds or so. Then (at around 40 seconds in) the mixture goes super-lean and it starts to run very poorly (this is at idle). Then, I rev it a little (to take it off of the idle switch), and you can see that the mixture immediately comes back to the 14.7 or so range (around the 1:57 mark in the video). It's still not running well at this new rpm (about 1500-2000), but at least the mixture is better. (then at the end of the video the O2 sensor falls out again, and the mixture reading goes to about 20 - which is what ambient air pretty much is).
What is interesting is how well it runs at immediate (cold) startup. This leads me to believe that we have some type of sensor problem (not an engine, exhaust, mechanical, or vacuum leak problem). I know from reading the BOSCH manuals that there is an immediate start-up / warm-up cycle that lasts about a minute to ninety seconds. It's running fine in this cycle (where rpm is about 1,100). As soon as this is over, and it lowers the rpm to 850 or so, then it starts being lopey, and the mixture leans out quite a bit. In at least one spot on the video, the O2 sensor fell out of the pipe (I don't want to clamp it down because it would scratch the tailpipe of the brand new muffler - maybe I'll get some soft brass or aluminum foil and mount it there more permanently tomorrow because it doesn't seem like this problem is going to be solved any time real soon. Thanks, Wayne <iframe width="560" height="315" src="https://www.youtube.com/embed/EeqYDWjlbro" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe> |
Are you sure about the statement on the O2 sensor being ignored. I know it has to warm up and is ignored for about 2 min when starting as it is still warming up, but then I believe it is taken into account.
The O2 sensor is to be replaced every 60K miles. When I did mine at 80K miles I noticed a much better warm idle. All your signals look Ok by the way. I haven't tested my inductive probe yet. How/where do you use it exactly ? If you PM me I can send you the official DME test plan document. |
1/ You could measure the lean/rich input from the O2 sensor on the scope and compare it to your external o2 meter to check ?
2/ Check the throttle Idle switch - does it clearly connect to GND ? 3/ Does it keep misfiring when you connect B and C terminals on the test port ? Sent from my iPhone using Tapatalk |
I kinda 'made my own' breakout box from a Volvo 940 ABS unit (same connectors). I included some leds to show the switched and see if the idle switch and WOT switch do connect to ground (pull the pin low).
First scope img : speed sensor, amplitude should be >2V Second scope img : 2 channels of the ICV valve pulsing http://forums.pelicanparts.com/uploa...1588504516.jpg http://forums.pelicanparts.com/uploa...1588504516.jpg http://forums.pelicanparts.com/uploa...1588504516.jpg |
Mine won't run if the AFR gets above 16. Never liked the exhaust robe for accuracy. You smoke tested cold but how about during the time when it is going lean. Always sprayed something around the intake looking for the problem in these conditions.
Good luck! |
"- New plugs, cap and rotor"
Did you forget ignition cables? At this point I would not assume anything...even simple things. |
What's it do with the O2 sensor unplugged? What is the initial CO reading at hot idle with it unplugged? HC reading at hot idle? Tried another airflow meter yet?
With the O2 disconnected, the measured voltage there should be about .50V. |
once the engine enters the "warm" mode. |
What is the cold start AFR?
Check the fuel quality switch on the DME. Position 3 and 7 remove 4% fuel roughly. Position 0 is stock, which is full counter clockwise. Two things come to mind with the AFM. Is it missing the silver plug over the CO adjustment port? This changes the mixture at idle. At hot idle, pull the o2 sensor and look at your AFR. It should be very close to to or just under 14.7 . May want to try setting 'baseline' with the Motronic. Hot idle, pull o2 sensor and adjust the CO adjustment screw on the AFM to 14.3-14.7 AFR. Reconnect o2 sensor. Jump the test port plug to disable the ISV, then reset your idle speed. Your AFR should not change much. I think over the years many make adjustments using the CO port to try and get the car to pass. If the silver plug is still in place on your AFM, then this is probably not your issue. Does the black cover on the AFM look like it was removed? My 3.2 was very lean running when i purchased it. The clock spring in the AFM is factory set, this sets the tension on the 'barn door' of the AFM. I found that in the 160k miles my car covered prior to my ownership, the AFM clock spring was likely adjusted to increase spring tension, thereby leaning out the mixture...no doubt to pass emissions at some point because it was running rich. This should NEVER be adjusted as they are likely factory set with a flow bench. http://i.imgur.com/FbtnjZ8l.jpg This thread explains the clock spring well and is what helped me with my issue. For peace of mind, i was able to find a low mileage unmolested AFM i currently use. http://forums.pelicanparts.com/porsche-911-technical-forum/835870-afm-mixture-am-i-lean.html |
Also as mentioned, the o2 sensor is used at warm idle by the DME for a target afr of ~14.7. Its only ignored when the wide open throttle switch is active. Are you sure the O2 sensor is good? If you disconnect the o2 sensor at hot idle, it defaults back to a preset fuel map on the chip (like how the euro 3.2 motronic is setup)... you should see ~14.7 or slightly richer.
Still, that is indeed a good suggestion, and I will check the running voltages and map them against my wide-band LM-1 sensor today to see if they match. I will also try unplugging it. What makes me think that the O2 sensor is okay is the fact that the mixture appears to be fine when the the throttle is raised just off of the idle position. It still has the miss at this point too (or it did the other day). So, if the O2 sensor was bad, *and* it was used at idle, then it would seem to have problems both at idle *and* about 2000 rpm. Instead, the mixture drops right down to 14.7 at 2000 rpm, which led me to (for now) assume that it was functioning property. Still, it's relatively easy to test, and I'll be including it in my test plan for today. thx, Wayne |
-Wayne |
As others have said, the O2 sensor is used at idle, it just does not output a usable signal for the first minute when it is stone cold, until either the internal heater of the sensor or the exhaust heats it up, then outputs a signal the Motronic uses. So that said, a faulty O2 sensor can cause strange idle issues, so you can disconnect it and if the issues go away, look to replace the sensor. So how does the car idle with the O2 disconnected? The car does not really need the O2 sensor to run if there is no cat in the exhaust.
A very lean mixture reading on a wideband can be cause by an excessively lean mixture, and excessively rich mixture, or a misfire of some sort. If you can set the base idle mixture, set it with the O2 disconnected to between 14.2 to 14.4 at normal running temp. If you cannot get a clean reading to set it, then as a baseline, turn the idle mixture screw all the way in clockwise, and turn it back out about three full turns. The screw falls out after about 11 turns. You want to take a improperly set idle mixture out of the equation. Next do you have another 3.2 Motronic unit you can swap with and see if there's any difference? Faulty or failing units can also cause all kinds of intermittent and poor running issues. Also how does the distributor rotor phasing look compared to TDC on the crank pulley? Turn the crank pulley and as the TDC mark approaches the mark on the case, look at where the rotor points to the TDC mark on the distributor housing. If the rotor is more than 3-4°s off, the rotor will not properly contact the distributor cap, causing various misfire issues that appear to be a lean condition. Improper rotor positioning can occur on engine rebuilds where it is inserted one tooth off, or in some rare instances of very early 84s built in 83, the worm gear on the crank was positioned 180 degrees off which would not allow the rotor to clock correctly in one tooth position or another. The only solution to this was a recall by Porsche decades ago, or take the distributor and remachine the shaft to reposition the worm gear on it to allow proper repositioning. |
The reason why I don't think the plug wires are the culprit (or anything part of the ignition) is that the car runs fine for the first two min or so, and then starts to miss. It also goes lean at that point. Ignition problems would show up at the first moment, and they wouldn't necessarily cause a lean mixture to occur immediately following a normal warm-up period. Still, the wires could be suspect, but my gut tells me (at this moment) that the problem lies elsewhere? -Wayne |
Interesting story, this engine was a replacement for the 2.7 that "blew up" in the car previously around 2001. That engine then became the "rebuild engine" for the 911 Engine Rebuild book I wrote. That 2.7 engine was disassembled and sold off in pieces. The 3.2 engine sat until 2009, until I had someone go thru it and put it in the car for me. When it came back in 2009, it never quite ran well, and it sat until about 2016 when it was stolen. Then I recovered it (tracked the guy down - he's back in jail) back in 2018 and we had it painted (that took a year). Now it's back and almost done, and I'm now tackling the engine running issues that I knew I had in 2009 (they didn't magically fix themselves unfortunately). I'm not sure what happened to the car while it was out of my control (it was left outside for about four months at the auction company where I had to buy it back). So, this is almost the last thing that needs to be done with it - I'm very close. -Wayne |
Thanks! -Wayne |
Test plan for today:
COLD: - Re-check the grounds to the engine and the pins on the DME using the breakout box. - Re-check the idle switch to ground at the DME (I'll also recheck the WOT switch). Install new throttle-return springs (just got them in, mine were a bit slow to return the throttle switch to closed). - Check fuel pressure (I hope I have the correct adapters here at home) - Check the vacuum controled fuel pressure regulators by pulling a vacuum on them and then looking at the fuel pressure gauge (although they shouldn't theoretically change 1-2 min after starting the car). - Mount the LM-1 O2 sensor into the tailpipe too - I've just been sticking it in there for the time being, but I think this problem is not going to be sovled any time soon. - Check the proper operation of the TDC sensor using the starter (the procedure detailed in the factory manuals) - Check the proper operation of the rpm / speed sensor using the starter (the procedure detailed in the factory manuals) - Jumper pins B&C on the test port and test / check mixture and misfire. START / WARM-UP: - Check the cylinder head temperature switch (use the breakout box to map this on the oscilloscope). I'm going to hook up my laptop to the scope to record the data in real time to review it later on (this scope is pretty awesome for $200 - Chinese made, but it has a *ton* of features). - Check the proper operation of the O2 sensor (both the heater, and map the voltage valves against the readings on the LM-1 meter). I'll probably need to take a video of this, as I don't have the LM-1 setup to dump data to the computer right now (that would take a bunch of time to do). - Unplug the O2 sensor to see if forcing the car into open-loop mode will improve things POST RUNNING: - Check temp control switch / Thermo valve (this is plugged off - may be leaking when warm?). What I'll do is take the car and perform my measurements until it's hot, and then I'll bring it back into the garage and put the smoke machine on it and see if we have any leaks at temperature. - Analyze results and post back on the forums! -Wayne |
Have you disconnected the O2 sensor when the car starts to run poorly? At warm idle, the base maps are altered by the Lambda sensor in closed loop operation and barometric sensor. That's it I believe.
Since the car starts and idles well cold (before o2 sensor is warm and working, aka open loop) the pre-programmed enrichment from the Motronic seems to be working. It's getting a cold signal from the temp sensor and an open aux air valve in the intake to keep the idle higher and overcome cold oil/pumping losses etc. The thermo time switch and cold start injector only operates for a brief time whe key is in START position, and a leaking cold start valve will make you run rich not lean. Once warm, you may be going lean because the o2 sensor is detecting a false 'rich' condition and decreasing the fuel injector opening time/fuel volume. One trick to see if you are truly running lean is disconnect the vacuum line on the fuel pressure regulator and to give it atmospheric pressure instead of manifold vacuum. This will essentially raise your fuel pressure and add more fuel- see if it improves your running or AFR slightly. This can be done with o2 sensor ON as a way to manually 'force' more fuel into the cylinders. |
Use a short bungee cord, one end hooked to the LM-1 clamp, and the other end to some part of the car like a fender strut, to hold it in. Or some tie wire. The clamp screw is not reliable. |
I was wondering if anyone reading this thread knows what the ‘correct mixture’ voltage output would be for the Bosch O2 sensor ?
The info out there is confusing, sometimes I read 450 mV, other times 350 mV for 14.7. I know it is narrowband and has a steep curve around the ideal mixture point but I 100 mV on a max of about 880 mV is a big deal. Sent from my iPad using Tapatalk |
Sunday Update:
- Rechecked the grounds using both the engine and the breakout box -> OKAY. - Rechecked the idle switch -> OKAY - Checked the throttle switch - it wasn't working. Since this is a wide-open throttle switch, it shouldn't affect the engine. I had a big issue with this. I checked the sensor using the breakout box and it didn't work. Then I disconnected it and checked the harness. Then I checked the sensor itself (hard to reach). Everything checked out, but when I buttoned it back up together it didn't work. So, I removed the switch (messed it up in the process - it's near impossible to get to on a 914 - probably a 911 too). I ordered a new one. Anyways, the problem was a defective harness with two pins - they were not seated correctly! It actually looks like it may have been defective from the factory. The pins are recessed in this connector. Doesn't fix my problem, but it was another problem that I found (it's good to check *everything*). The idle cutoff switch connector is shown next to it for comparison. See the photos: http://forums.pelicanparts.com/uploa...1588574046.jpg http://forums.pelicanparts.com/uploa...1588574046.jpg If you've ever wondered what this looked like inside, there really is absolutely nothing complex inside. It's criminal that the Porsche list on this thing is over $400! http://forums.pelicanparts.com/uploa...1588574046.jpg - Checked the fuel pressure. Showed 2.5 bar with the engine off (fuel pump jumpered), and also kept the pressure after the engine was turned off. Kept pressure during running too. -> OKAY I didn't have the proper fittings at home, so I used some hose clamps. These worked better than I expected (no leaks!) http://forums.pelicanparts.com/uploa...1588574046.jpg Pressure good: http://forums.pelicanparts.com/uploa...1588575570.jpg And after the car was off for quite a while, still holding: http://forums.pelicanparts.com/uploa...1588574046.jpg - Checked the Top Dead Sensor (TDC) sensor -> OKAY Photo: http://forums.pelicanparts.com/uploa...1588574046.jpg - Checked the RPM / speed sensor -> OKAY Photo: http://forums.pelicanparts.com/uploa...1588574046.jpg - Checked the cylinder head temperature sensor, I think the readings looked okay: -> OKAY - 747 ohm @ 75 degrees F - 315 ohm after two min of running - 155 ohm after ten min of running - Checked the ambient air temp sensor: -> OKAY - 755 ohm @ 75 degrees F - 755 ohm after two min of running - 700 ohm after ten min of running - Checked the O2 sensor heater element power (got 12V) -> OKAY - Checked the O2 sensor by measuring it against the wideband LM-1 tool. The O2 sensor appeared to be jumping all over the place. I've actually never compared these two in real time before, so I'm not sure what the O2 sensor output is supposed to look like. But it certainly didn't seem to be matching the LM-1. So, when I unplugged it, the car improved, but still did not run super well. The lean mixture came down and it ran closer to 14.7, but not spot on. I still need to adjust the mixture / air bypass screw on the air meter. What is troubling is that when I unplugged the O2 sensor and then ran the car at 2000 rpm, the mixture was off rich by about 10%). When I plugged the O2 sensor back in and ran the car at 2000 rpm again, the mixture was spot on. So, I have the following confusing situations: - O2 sensor plugged in, runs terrible at idle - O2 sensor un-plugged, runs better, but not great at idle - O2 sensor plugged in, mixture is spot-on at 2000 rpm - O2 sensor un-plugged, mixture is off by about 10% or so at 2000 rpm So, based upon the results at 2000 rpm, it would seem like the O2 sensor is indeed properly measuring the exhaust. Un-plugging it creates what appears to be an open-loop situation. Plugging it back in makes the mixture spot-on. Yet, there is something terribly wrong with the car at idle with the O2 sensor plugged in. Why would the O2 sensor appear to be failing at idle, but not at 2000 rpm? The answer must be obvious - it's probably not failing, but perhaps would be something else. - After running and the car was warmed, I smoke-checked the car one more time. No leaks were found anywhere - the intake is very tight (the smoke machine rubber funnel kept popping out because of the 10+ psi in pressure that was building up). I cracked open the air flow meter and also cracked open the throttle just to make sure there was enough flow everywhere. Here's another odd thing I recently noticed. I pulled the paperwork for the engine from 2003, and it says it was a 1984 engine (I thought it was out of a 1986 car). The engine number is 64E01127 - according to the appendix in my Engine Rebuild Book, that does confirm that it's a 1984 engine. However, the oxygen sensor has the round connector and the integrated three pronged plug, which supposedly didn't show up until 1986. So, something is a bit weird with this - a 1984 car should not have that plug. There's something amiss here, maybe the injection got swapped sometime, or something like that. Or it's a replacement harness. Something's fishy. |
Video of the car running rough, while monitoring the O2 sensor:
<iframe width="560" height="315" src="https://www.youtube.com/embed/YK6zr94i5aM" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe> Now the same thing, but then I disconnected the O2 sensor (sorry, the iphone got confused) <iframe width="560" height="315" src="https://www.youtube.com/embed/9jGPjP127EQ" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe> Short video with O2 connected: <iframe width="560" height="315" src="https://www.youtube.com/embed/beNoCbfqfTM" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe> Now disconnected (mixture is good, but it's still missing): <iframe width="560" height="315" src="https://www.youtube.com/embed/LWMJiHiYwwk" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe> http://forums.pelicanparts.com/uploa...1588574649.jpg It passed the warm smoke test: http://forums.pelicanparts.com/uploa...1588574649.jpg http://forums.pelicanparts.com/uploa...1588574649.jpg This is the ECU that is in it: http://forums.pelicanparts.com/uploa...1588574649.jpg Weirdness - this seems to be associated with the following: 1988 - '89 0 261 200 082 - uP PN B57312 4006, Date Code 8808, 28 pin EPROM That and the newer wire harness indicate that something is odd and this motor is not as unmolested as I had originally thought. Still, I don't have any reason to doubt that there's anything seriously wrong with it - it does indeed run well for two minutes. I have not run a compression check on it (didn't think I needed to). The engine serial number says that it's a 1984 engine, so there's something amiss. It's possible that the person who installed this into the car used a different brain and harness for some reason - I can't recall and I can't find my paperwork right now. Still, it theoretically shouldn't make any difference? -Wayne |
Wayne...you have to make the videos public in options no they are private we cannot see it
Ivan |
I've got a new wide-open throttle switch that I will get tomorrow along with a new O2 sensor. But in the meantime, I'm open to further suggestions. I'm not very hopeful that a magical new sensor will fix the problem?
-Wayne |
-Wayne |
now there are no videos to see....i`m sure you did this already just a thought... reference sensor .08mm distance from the flywheel is set ,right?...
Ivan |
Hit refresh? I just checked it from an anonymous browser and it worked?
Thx |
i did and no videos anywhere to see???
Ivan |
Videos work for me
all ok now thanx.....
the last video ...how come suddenly it runs ok with the oxy disconnected...do you have to have it in the system ..or can you just bypass it at the ecu and not use it at all?
Ivan i assume the ref sensor gap is ok ,right? |
Back to basics old school here. Grab a can of carb spray and spray it into the intake with the engine running. Verify that the O2 sensor reading on your breakout box goes up (Using a DVOM set to DC volts). All it takes is a little bit, we just want to verify that 1) the O2 sensor responds by reading an output closer to 1.0V, and 2) see if the engine smooths out. If both things occur, look for a vacuum leak somewhere, or possibly the AFM is off. In any case, if it smooths out, we KNOW that it's lean and fuel related.
O2 sensor should read about 450mV unplugged (Key on engine off), close to 1.0V full rich, close to 200mV really lean (engine running). The number of times it crosses the 450mV threshold while in closed loop is what we used to call "cross counts." The more the better. A "lazy" O2 sensor will hardly ever cross the threshold and new (or good) O2 sensor will cross the threshold constantly. The 450mV is actually an output from the ECU, and the computer just cares if the voltage goes above or below that point in order to adjust the A/F mixture. |
It is typical on engine transplants that components are cobbled together from different years, so yeah you have a early harness, and a later brain, but it doesn't really matter. The brain you have can be either an 87 with a 24 pin chip, or 87-89 with 28 pins, for which the base idle speed is to set and should idle around 880 rpm.
Your O2 sensor readings being fixed around 0.49v are symptoms of a worn or dead O2 sensor, so replace it. Normally it should switch rapidly several times per second from 0.2 to 0.7v around stoichiometric, or stick mostly under 0.2v is the car is running lean, or above 0.7v is idle is running rich. You didn't mention what the exhaust was, but I'm guessing some kind of aftermarket header system configured for a 914? If so it's important that there's no exhaust leaks especially around the flanges, which can suck in air and fool the O2 sensor into sending out incorrect readings. Aftermarket headers often have poorly planed or warped flanges, though the stock manifolds can too if the gaskets were reused. |
you may have a poor injector spray from some injectors. You need to remove each injector connector separately and determine it's effect. You can also pull each spark plug connector to find a missing/weak cylinder. |
If by ambient air temp sensor you mean the air temp sensor in the air flow meter, those are also off. Low readings here will cause a richer mixture. The NTC sensor in should read as follows: 32F between 5.0-6.2k ohm 68F between 2.2-2.8k ohm 86F between 1.5-1.9k ohm If you don't have another air flow meter at the moment to substitute, you can try substitute a 1.7k ohm resistor here temporarily here to assist in debugging if the sensor really is found to be faulty. |
Use an IR temp tool on each exhaust tube. Did you get a CO reading out the tailpipe? HC? The mixture has to burn before you get CO. High HC shows unburned fuel. But you Knew that.
| All times are GMT -8. The time now is 11:26 PM. |
