Reverse Lockout - Not
Installed a Rennshift with automatic reverse lockout a year ago and has worked perfectly since. Yesterday I started to get a major crunch when downshifting to 4th. The lockout pawl seems to be operating flawlessly and the shift rod bushing and coupler bushings are all new and just inspected. I can downshift fine but need to pull into neutral and let the spring gate take it into the 3-4 plane.
Several months ago I did pull the transmission and had some work done on 1st and 2nd gear. I hope nothing is going on there.
Walt 82SC 3.0 81SC 3.6 |
Rescuer of old cars
Sounds like the coupler adjustment could stand to be fine tuned.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
The directions from J West are very straight forward for coupling adjustment, almost fool proof. I guess I could try a tweek in both directions. Odd that it happened so suddenly.
Rescuer of old cars
Well, you might also look at the engine and transaxle mounts, it may be allowing the drivetrain to shift a little.
Been here a while
if the tapered pin in the shift coupler backs off just a touch, you will have enough play in the linkage to cause your problems. Check that everything is tight prior to re-aligning the coupler.
looking for 1972 911t motor XR584, S/N 6121622 |
