I think people who rub their car with a diaper, drive it 200 miles a year, and mothball it 6 months a year since they only drive in 72F or warmer are more likely to suffer broken head studs. Sad !
1986 Bosch Icon Wipers coupe. |
disband
^^^^ that shows just how informed you really are.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Mighty Meatlocker Turbo
The lower/exhaust sides break because the dilivar alloy used was garbage (until the 993TT version) - plenty of instances reported where brand new ones broke upon assembly, which rules out corrosion being the only negative factor.
The cylinders slide into spigots in the crankcase. 4 studs/cylinder, anchored in the case, snake through each cylinder and each cylinder head. The one-piece cam housing then clamps onto the three cylinder/cylinder head assemblies as one structural assembly. So no.
One or several head studs, even if simultaneously breaking, will not allow a cylinder to fall out or shift to any appreciable distance to implode the engine. This is not to say the engine cannot self-grenade. That requires other major component failure to occur. I’ll leave that scenario to your follow up question. Sherwood |
Fleabit peanut monkey
Seriously. It's old school. Pretty cool stuff and Anderson is a good writer.
1981 911SC Targa |
Tell your Mom I said Hi.
1981 911SC Targa |
).You sister just gave my mom your message, bro!
