sugarwood's Avatar
I think people who rub their car with a diaper, drive it 200 miles a year, and mothball it 6 months a year since they only drive in 72F or warmer are more likely to suffer broken head studs. Sad !
1986 Bosch Icon Wipers coupe.
Old 05-08-2020, 12:42 PM
disband
juanbenae's Avatar
^^^^ that shows just how informed you really are.
Old 05-08-2020, 01:13 PM
proporsche's Avatar
1985 911 with original 502 191 miles...808 198 km
Old 05-08-2020, 01:30 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
The lower/exhaust sides break because the dilivar alloy used was garbage (until the 993TT version) - plenty of instances reported where brand new ones broke upon assembly, which rules out corrosion being the only negative factor.
Old 05-08-2020, 02:06 PM
The cylinders slide into spigots in the crankcase. 4 studs/cylinder, anchored in the case, snake through each cylinder and each cylinder head. The one-piece cam housing then clamps onto the three cylinder/cylinder head assemblies as one structural assembly. So no.
One or several head studs, even if simultaneously breaking, will not allow a cylinder to fall out or shift to any appreciable distance to implode the engine. This is not to say the engine cannot self-grenade. That requires other major component failure to occur. I’ll leave that scenario to your follow up question.
Sherwood
Old 05-09-2020, 12:58 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Maybe you could get a copy of Bruce Anderson's 911 Performance Handbook and read through it. It would be an investment in your credibility.
Seriously. It's old school. Pretty cool stuff and Anderson is a good writer.
1981 911SC Targa
Old 05-09-2020, 02:05 PM
Bob Kontak's Avatar
Lion's share is pitting and axial shear post heat cycling.
Tell your Mom I said Hi.
1981 911SC Targa
Old 05-09-2020, 02:08 PM
Agreed with that - amazing how weak and non-resilient those studs are (must be millennial "studs" ).
You sister just gave my mom your message, bro!
Old 05-10-2020, 12:58 PM
