need help finding 35mm intake gaskets
I'm trying to reassemble the induction on a race motor with carbs
went to my gasket selection and found gaskets in 34mm, 35mm, and 36mm in my stash....
unfortunately only 6 of the 35's... and I need 12 with the phenolic blocks
So the heads have been worked, and the Intake Port is 35mm
looking through different years of factory ports... I see the early S cars are 36mm
but somehow I have those extra gaskets in my parts box that are actually 35mm and fit perfectly....
does anyone know where they could have come from?
I'd like to buy 35mm Intake gaskets
looking at the 2.7 gasket pictured here on the pelican site... they appear to be a different shape for the CIS, and although they are 35mm I'm not sure they will work with my carb set up
can anyone help guide me?
thanks in advance
brant
914/6 2.0S with twin plug
all metal body panels
19quarts of oil
4 gallons of gas
and 1826 lbs (wet)
Old 05-23-2020, 07:45 AM
I had the same problem and finally gave up and bought a sheet of intake gasket material and made my own. They fit better than the factory gaskets in that I cut them to match the out perimeter of the heads, injector blocks, insulators and intake.
Good luck!
Bill
1987 Marine Blue 911 Carrera Coupe RIP 01/2011
1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint
Old 05-24-2020, 07:50 AM
