Rear shocks for a 75, what's different than 74's?
I'm trying to go with Koni Classics on my 75, but it looks like they only make them for up to model year 74. Seems those would fit a 75 as I can't see any difference, but was there a change back there from 74 to 75's??
Bill
Current: 1975 911S --Chocolate brown Past: 1967 911S --Bahama Yellow 1990 C2 Targa --Silver 1973 914 2.0 --Delphi Green |
Under the radar
There should not be any difference in rear shock size from ~'73 through '88.
EDIT: after researching I should have said '74 to '86.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 05-08-2020 at 11:28 AM.. |
That was my thought, but all catalogs break down the rears to 72-74, then 75-89. Trailing arms look the same, and I can't identify what would be different up top, but there's got to be something.
Under the radar
Unless '74 is unique and had a different bottom mount size bolt? When Porsche went to the aluminum trailing arms they also went from a 12mm bottom bolt to a 14mm bolt. At any rate the old catalog I have lists '75 to '86 as the same shock. Edit: Looking further, I see that Bilstein lists the same rear shock from '73 to 89. So go figure.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 05-08-2020 at 11:43 AM.. |
PRO Motorsports
!975 was the year they went to 5mph bumper law, and i would suspect it also coincides with the bumper height being raised.
So it makes sense that '75-on would come with a slightly longer shock. For our use, the '72-'74 should work just fine in later cars, as I don't think there are too many cars on the road anymore that are still running that crazy high U.S. ride height they came off the boat with. There's a chance that the extended and compressed lengths are the same but have different length bump rubber.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
big bumpers on 911s came in 74, not 75. US Bumper law was 5mph front and 2.5mph rear for 1973, 5mph on both ends for 1974.
'80 SC Targa Avondale, Chicago, IL |
I know of 2 changes to the 911 rear suspension
'72 E-series relocated both the upper and lower shock mounts to eliminate a rear ward and inboard tilt of the shock '74 G-series got alloy semi trailing arms
gearhead
I’ve got the full suspension from an 85 Carrera on my 74.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
PRO Motorsports
But the point of my earlier post was about the bumper height law resulting in the raised ride height.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 Last edited by Tyson Schmidt; 05-21-2020 at 09:51 PM.. |
gearhead
Raised ride height was for US '75-83
This is the correct answer which means in theory, you should use the 74 shock if you are lowering your car. Went around with the suppliers about this for a long time including our host. There really should be a footnote on the product page explaining it.
In the front, they dealt with it by adding the famous spacer on top of the strut which everyone says you have to remove when lowering your suspension. Quote:
Registered Minimalist
I should dig my woodhead shocks out from my 75 and see how long the bump stop is..I did have the 10mm spacers up front. They stopped using the spacers just a few years later though, I think maybe 81? So wonder if that changed the rear shock length at all...
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
