'75 3.6 Conversion Tins not level??
So my Rat Rod's tins look angled. The front of the engine (transmission side) has almost a 2 finger gap between the body and the tins. The rear is barely not touching the body, and the sides obviously slope. Yes, my rubber gaskets are out. In looking at a friends stock '75, his are almost even all the way around. In talking to a mechanic, he said the "blade" on the bottom of the block should be parallel to the ground with the car on level ground.
My question is, how do I know if my engine is tilted up from to back, or if my 3.6 Tins are the issue in my '75 body? Who ever did the conversion in my car just put a bunch of washers under the engine brace, and I want to clean that up, get the gaps right, get propper bolts and make my own spacers that are one piece, and replace the rubber gaskets so the top half is sealed from the bottom.
The car has a 3.2 engine brace on it, as the A/C compressor and the 964 crank pull have been swapped for Rothsport parts.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 05-13-2020, 02:46 PM
Bill Verburg's Avatar
964 or 993?
The 964 f/i stack sits a bit higher, so the 964s tend to sit a bit lower and tilted than 993 unless the package shelve is clearanced
Bill Verburg
Old 05-13-2020, 02:52 PM
Bill, 964. It's not that I notice that angle is incorrect from the top of the motor. In fact I have the clearance I need to the package shelf. It's more that I see it at the tins, and the front seems lower than the back. Based on your description I would think the 964 engine would need to be lowered more than a 993 to gain clearance at the package shelf, making the front (transmission side) be higher than the rear. Mine seems to be the opposite.
I know that the bolts and spacers are goofy, that is has a 3.2 engine brace too....and want to get proper bolts and make proper spacers to have the engine correct. Any thoughts on how to accomplish that?
Old 05-14-2020, 08:30 AM
Anyone?
Old 05-15-2020, 12:31 PM
Originally Posted by Duc Hunter View Post
Anyone?
They are all custom made to fit the best possible, I'd situate the motor as high as possible then address the tins on an hoc basis
All I know is that the 964 motor I used sat lower than either 993, all sit lower than a 3 or 3.2. The issue is dragging the muffler on inclination changes
Bill Verburg
Old 05-15-2020, 12:37 PM
Bill,
Thank you so much for the help. Makes sense. And it sounds like you "don't care" if the motor is not level front/rear," just that it fits under the parcel shelf? I believe I cannot raise the transmission, all the adjustment is done at the engine side?
Old 05-18-2020, 01:22 PM
Bill,
correct, the trans is pretty much fixed but the rear motor mounts will have custom made sleeves to accommodate the best fit in the chassis
Bill Verburg
Old 05-18-2020, 02:18 PM
