Valve Adjustment ? Help..
Hello all,
I have had my 78 SC for about 4 years now taking care of all the little things that need some TLC. I have rebuilt all my calipers and pistons, replacing old hoses etc, new spark plugs, cap and rotor etc and have decided in taking the plunge to adjust the valves. I took the left top cover off and found this pin laying on the engine bay. Before I move forward I want to make sure I know what this is and is this a bad sign of something? Maybe it just fell from the sky and I'm good to go. I also have a pic of my valve cover, why the heck is it so dirty, what is this telling me? Any help much appreciated.
Thanks,
Boogers
Old 05-10-2020, 11:38 AM
Looks like a head stud to me. Usually they break with the nut still on the end...so I'm not so sure.
Just to clarify...you found it under the valve cover..right?
If so..it must be a head stud. I just wonder where the nut went??
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 05-10-2020, 11:41 AM
proporsche's Avatar
when you said engine bay ..do you mean in the engine compartment or inside the engine behind the valve cover??Can you make a bigger pic of it..for a broken engine case stud ,this looks way to sharp on the edges...
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 05-10-2020, 11:52 AM
Maybe part of a tool that was dropped in there whilst other work was being performed.
Old 05-10-2020, 11:55 AM
Take a pick of the pointed end head on.
Old 05-10-2020, 11:56 AM
Mysterious object.........
Booger,
That piece (rod) you found in/on your engine is NOT part of a cylinder head stud. It is a tool inadvertently left by someone who last worked on your motor. While you are there, remove the lower valve covers and inspect the barrel nuts for the lower cylinder head studs.
What is the diameter of the mysterious piece? The cylinder head studs are approximately 8-mm in diameter. Keep us posted. Thanks.
Tony
Old 05-10-2020, 12:11 PM
sugarwood's Avatar
Start a new thread and title it, "Found this under the valve cover. Is it part of the engine or a tool?"
1986 Bosch Icon Wipers coupe.
Old 05-10-2020, 12:15 PM
Now that I think of it that looks like part of a spring loaded punch tool.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=2ahUKEwiT4r-UgarpAhUDCM0KHZ2jAhIQwqsBMAB6BAgMEAQ&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DV3 r7vE8Di0A&usg=AOvVaw2qSYK7tZRFXqC20gO07-XR
Old 05-10-2020, 12:16 PM
I think he meant below the VC on the sheet metal. Not sure though.
Old 05-10-2020, 12:19 PM
Thanks all for the help, I just want to make sure I'm not going to screw my engine up by finishing up and putting my covers back on.
proporsche, when I took the top left cover off, I was just laying there just under the valve cover below the #1 cylinder on the engine sheet metal tray. I don't remember any kind of clank so I don't think it fell out but I'm not 100% sure.
Here are some better pics.
Old 05-10-2020, 12:37 PM
Looks like brass.
Old 05-10-2020, 12:42 PM
Looks like a punch to set upholstery snaps. Although that would be very odd in the engine bay.
Certainly not a head stud. You dodged that bullet!
Maybe buy a lotto ticket today
Old 05-10-2020, 12:46 PM
proporsche's Avatar
As the boys said ..you are lucky ..then again it was not inside the engine..good for you..it could be anything..my guess is homemade pin when you do the camshaft timing..and when the person was removing it from the bracket it has fallen on the space where the spark plug goes....just a wild guess thou.....add.i c on the sheet metal same thinking from me..some kind of helping tool..
Old 05-10-2020, 12:57 PM
As far as the black substance that's normal it's open to the atmosphere.
Old 05-10-2020, 01:01 PM
Thanks all for the great feedback!. Just an odd piece to find for sure. Have a great Mothers day all!
Cheers,
Boogers.
Old 05-10-2020, 01:18 PM
