LinkBack Thread Tools Rating: Thread Rating: 5 votes, 1.00 average.
sugarwood's Avatar
Why doesn't broken head stud destroy the engine within a few seconds ?
This is something I have never understood. I assume the head stud holds the head in place. There are 2 or 4 per head? There appears to be a long rod passing through the cylinder and head.
If the stud also holds on the cylinder, when it breaks, I would expect the cylinder and head to move. The piston is attached to the connecting rod and has a very tight tolerance. If the cylinder moved, I would think the piston would smash into the cylinder wall, and destroy itself instantly. Why does this not happen, and people drive for years and not even know they have a broken head stud.
Or does only the head move and there is no way for it to hit the piston, since it can't get any closer due to mating surface of head being fixed.
I get if only one is broken, maybe the other cylinders keep it from shifting. But, how many can you get away with. With 2 studs broken, I would think the above scenario would be inevitable.
1986 Bosch Icon Wipers coupe.
Old 05-06-2020, 02:39 PM
Travis Neff's Avatar
There are 4 headstuds per cylinder. all headstuds on each engine side bolt the cam tower with the heads sandwiched in between. The remaining unbroken studs hold the load keeping everything together.
72 914-6 GT Conversion 2.7
82 911 SC Coupe
78 SC Targa Hotrod
Old 05-06-2020, 02:54 PM
sugarwood's Avatar
Thanks. I am guessing 2 broken studs could still keep everything still. Any 2 corners of a square are fixed, the square stays fixed. So, it would take 3 broken studs from the same cylinder for a catastrophic shift in the engine causing interference?
Has anyone ever reported 3 or all studs breaking in the same cylinder and resulting in a catastrophic engine failure ?
Old 05-06-2020, 04:23 PM
206 637 4071
Old 05-06-2020, 06:04 PM
Just another Sugar’s favorite.....
Old 05-06-2020, 07:37 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Wood, the cylinder and head assembly doesn't move left or right, or up and down (as in up/sky and down/ground) much at all (as in basically not at all), even if many of the studs on a bank are broken (even just two remaining, intact studs would do a lot to steady that kind of movement, as everything is still held together, left to right & up and down, by the cam housing), but what happens is compression and combustion pressures lift the heads that have broken studs, and that allows combusting fuel and oxygen to escape, which then burns/erodes the surface where the heads meet the cylinders - even with such a slight loss in clamping force that there is no escaping combustion, you can end up with slight-movement-caused damage to those surfaces (called fretting).
You are not going to see catastrophic, 911 engine failures due to broken studs, as they do not break all at once (not even the super shiity, dilivar studs that Porsche used for decades and could not get right until the 993TT, do that), and when a couple of them have broken (even just one, for people with experienced and attentive ears), the tell-tail noise of escaping combustion is loud and clear, so someone who is thinking straight will not operate the engine further until repairs are made.
Old 05-06-2020, 09:22 PM
no problem.....
I drove my car for years with no issues, save the dirty block and a drip or two .. or ten
Jason
'79 911SC Targa
Old 05-07-2020, 03:48 AM
MBAtarga's Avatar
Looks like 3 broken studs above.
Mark
'83 SC Targa - since 5/5/2001
Old 05-07-2020, 05:01 AM
sugarwood's Avatar
The hypothesis was 3 broken studs in the same cylinder. Center cylinder has 2 broken.
I will try to find a photo of cam housing to understand how that keeps all 3 cylinders and heads from moving. I am guessing it is like an inverted egg carton with 3 eggs that "cups" and forces things to stay in line.
Old 05-07-2020, 05:11 AM
3 in 1 hypothesis.........
Sugar,
Are you aware why and where the broken head studs always occur? Take a closer look at Jason’s picture and you will find the obvious. The three-in-one (3 in 1) scenario has never been documented or not seen in the last 40 years. I doubt you will find one.
Tony
Old 05-07-2020, 05:35 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Your original post does not say three broken studs. It says two. Like Tony mentioned, the upper studs don't ever break. They just don't.
I echo the by others. Chicken little the sky is falling, here we go again........
Kevin L
'86 Carrera "Larry"
Old 05-07-2020, 05:50 AM
On my 85 3.2 engine I was doing my typical inspection after another long road trip at 150,000 miles total mileage and noticed a wetness on one head. No major leak, but a wetness ain't good.
I took it up to my engine builder and we dropped it, and started looking. Of course to get the head off, is a lot of digging. Got the suspect cylinder and one stud was loose. Not broken, it had somehow backed out of the case. No thread damage, no stud damage. Everyone says "I had never seen that before" and I guess I was the lucky lottery winner.
Of course the engine was grimy and gross after all those miles. If one side had an issue, we had to check the other side. And "while we are in there" struck big time and down the slippery slope to a full rebuild. New ARP studs for everything and rod bolts and might as well......................
Old 05-07-2020, 05:57 AM
donbecker1234's Avatar
My understanding is that although head studs breaking isn’t a “good thing”, the concern is gap between the cylinder and the case, possibly caused by a broken head stud.
1987 M491 Widebody, Nautic Blue / Linen with a 1979 930 3.3L Cali Engine
Old 05-07-2020, 06:19 AM
Don,
It is the top of the cylinder and the head that will separate, causing fretting that is the worry of permanent damage. This will require the head mating surface to be "cleaned" up some.
Rahl
1976 930 turbo Carrera, "Ubich". Mostly stock, lightly sweetened. She’s an angry schwierigkeit. She doesn’t want flowers, she just wants to dance! And when she does, she shakes her hips to the rythem of the road. Drive her like you hate her!
Old 05-07-2020, 07:32 AM
sugarwood's Avatar
Originally Posted by boyt911sc View Post
Sugar,
Tony
Why. I read that it's due to moisture. I did see Franny mention something about upper and lower bolts being different materials since different temps? Intake vs. exhaust?
I see that only the lower studs are broken. Looks like top ones don't break? Hence, never getting 3 of the 4? Thanks!
Old 05-08-2020, 06:15 AM
sugarwood's Avatar
https://youtu.be/-0gUImuE5e0?t=409
Old 05-08-2020, 06:18 AM
sugarwood's Avatar
Originally Posted by 356911930 View Post
Don,
Rahl
What if the fretting damage is beyond repair?
Can one simply buy a new cylinder and head?
What do those 2 parts cost these days?
Cylinder is $700
930-103-990-01
https://www.pelicanparts.com/catalog/SuperCat/911M/POR_911M_ENGPIS_pg1.htm
Cylinder head is $1500
930-104-033-06
https://www.pelicanparts.com/cgi-bin/ksearch/PEL_search_2016.cgi?command=DWsearch&description=Cylinder+Head+
Old 05-08-2020, 06:20 AM
Better in Person
juanbenae's Avatar
:d:d:d
Old 05-08-2020, 06:37 AM
On my engine, just that one stud was loose. All the others were still fine. None were broken. But that one stud allowed combustion gasses to escape, and damage the head a little. So it needed to be surfaced just a bit. Of course you can't do that without removing the head, and that really means all 6 heads have to come off. So a full top end has to be done. It would be really stupid not to do the valve guides, and clean up the valve seats. And since the heads off it is easy to pull the cylinders and check them. And while yer in there the rod bolts can be replaced. But heck, while yer in the re why not split the case and check it all out.
I was real glad we did split the case and the intermediate shaft bearing had a decent amount of wear. One of the rod bearings showed a little bit of a "hot spot" so while we were in there.........
In the end my engine was all better and I love it.
Before
After
Old 05-08-2020, 06:50 AM
Stranger on the Internet
patkeefe's Avatar
I think it is only possible to break three head studs in one cylinder if you use the wrong viscosity oil below 20F.
Patrick E. Keefe
78 SC
Old 05-08-2020, 09:26 AM
