3.3SS engine power
JackkTheMakk, Looks like your engine is coming right along! One thing I would mention is to be very careful assembling the engine case as it is quite easy to damage one or more of the oil pump seals that go between the oil pump and the block! I learned the hard way and had to tear down a brand new engine and do it all over again! A word to the wise! |
No have not started motor yet. Sent muffler to Brian for some custom work. Should have it back next week. Then off to Pinks for dyno and break in.
Slowly making progress. Ended up ditching my red box glyco GT3 rod bearings for Mahle/Clevite and purchased main bearings direct from Porsche $$. Worth the saving myself from the headache in the long run. Main bearings came out to .002” across the board with a dial bore indicator and plastigauge.
Waiting for my new rod bearings monday and then it’s go time for the short block. http://forums.pelicanparts.com/uploa...1598192211.jpg |
No, haven't started yet. Just installed the headers and 997 GT3 muffler. Hopefully this week. I will post a video http://forums.pelicanparts.com/uploa...1598192760.jpg
I did a top end on my 3.0 and ditched CIS for EFI/ITBs last year and at the time it stressed me the hell out as I was pretty budget constrained, but I also learned a ton and made a list of things I'd do if my rebuild blew up on me (so far so good, minus a slight leak), so it's fun to live vicariously through this thread as this is almost exactly what I *wanted* to do, heh.
Fun thread, thanks for sharing. |
Which EFI set up did you go with? |
http://forums.pelicanparts.com/uploa...1598202621.jpg |
I don't think so, when I looked in it was a straight shot in.
Yes, your correct. The red shows where the cut out enters the muffler. Straight loud and out the to the tips. This is definitely different. We will see how it works out. I hope it still gives me the sound I'm looking for.http://forums.pelicanparts.com/uploa...1598240404.jpg
http://forums.pelicanparts.com/uploa...1598240404.jpg |
Wondering what your rough budget is for this build. I am still on the fence between a 3.2ss and just turboing my 3L
Here's a short video of first startup of my 2.8 with 997 GT3 RS muffler/M&K headers. https://youtu.be/sCT58lyGs7o
