Replacing Front Strut Inserts
Hi,
I have a 1977 911 S Targa and I am replacing the front strut inserts. They are Bilstein and I have successfully removed the roll pin. The issue I am having is that I can't seem to angle the strut tower outside of the fender. It seems that the brake line is impeding it. Any tips or suggestions? Thanks, Kevin |
Unbolt the caliper and zip tie it somewhere safe so the weight isn't tugging on the brake line. Two 19mm bolts.
You should be able to compress the strut by hand. It will go slowly and the gas pressure will push it back out, so you have to move kinda quick. Put a block or something under the ball joint so you can push with both arms but not pull on the brake line.
Matt - 84 Carrera |
Whenever I've tried to get the top of the strut out of the fender without disconnecting to brake lines, I feel like I'm putting too much stress in the lines.
The last time I was in there, I used a stick to partially push the brake pedal (keeps the fluid from draining) and disconnected the brake lines. Soo much easier. I did follow up with a quick gravity bleed, but no substantial air was in the system. |
Rescuer of old cars
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
AutoBahned
might as well replace the rubber brake hoses - they're a maintenance item
BTW, split some rubber hose and use it to protect the fender lip |
Easy to remove the retaining clip from the inner fender tab and push the brake line through the tab. Then you can get the strut out enough to swap the insert. Don't even have to take the wheel off.
Thanks for the tips, I ended up disconnecting the brake line and was able to swap out the strut.
put masking tape on the fender lips. beforehand.
??? one is not supposed to have that issue that changing the strut insert would require to open the brake line and needing to bleed it afterwards!
maybe your brake hose was just that one cm too short? aftermarket? I always manage to get it done by lifting the front so it is free in the air and remove wheels. to change left insert (driverside), turn steering to the left as much as needed to give the hose some "length" and reduce stress but in the end that was the reason I changed the hose setup completly. also easier now to remove the caliper and place aside to change the disc
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
See that flat C clip in the pic? Pull it out and push the metal line through the tab. Won't stress anything. 10 minute insert swap, start to finish.
This is how I did mine.
2000 Boxster S and 2016 Audi A6 |
I'll try to remove the C-clip on the other side and see if that gives me enough range. |
see the the silver bracket midway fixed with a bolt to the strut? I now can remove it and the whole brake line is "loose".
Sorry I'm used to working on cars with raised spindles where the brake line brackets on the strut can be removed easily, sounds like John Walker has the best method.
Nice job Flo looks great.
1984 3.2 cab india red 1970 1192 Volkswagen Beetle |
