VFR750's Avatar
Stop Tech Level 2 front brake kit
My stop tech L2 front brake kit just arrived.
Amazingly good packaging and the parts look fantastic. Confirmed 32mm leading and 36mm trailing pistons. 100% compatible without the need to change the master cylinder.
Rotors are beefy and have a hat design that really isolates the hot rotor from the hub.
Here is the difference in size between the STR-43 caliper and the stock ATE caliper. Pad volume difference is 2x.
Comes in two boxes. All packed to prevent damage and keep the box weight to ~25
Lbs. left and right rotors and calipers. Nice aluminum adapters. 309 pad compound included
You can see the swept cooling fins (44 total). And the minimal contact between the hat and the rotors.
Old 06-17-2020, 04:47 PM
Is there an unsprung weight penalty?
Brian Miller - Scottsdale, AZ
1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S
Old 06-17-2020, 09:18 PM
VFR750's Avatar
Aluminum Calipers are much lighter. Rotor is heavier but the hats are aluminum. Probably a wash; my scale is not accurate enough to tell.
Old 06-18-2020, 02:14 AM
VFR750's Avatar
Stop tech kit is 5 lbs lighter
Had to double-up the parts and level the scale to get repeatable measurements
I’d treat these numbers as relative and not dead-accurate.
SC system 39lbs
21 lbs - 20mm rotors
17 lbs- ATE M steel calipers
1 lb - pads
Stop tech level 2: 34 lbs
21 lbs - 28 mm rotors and hats
11 lbs - aluminum calipers and adapter brackets
2 lbs - pads
The assembled rotor uses both steel and aluminum efficiently verse the all steel 20mm rotors
Note the Carrera front brakes are even heavier with the wide-M calipers and 24mm rotors.
All aluminum calipers are significantly lighter than stock steel calipers.
Old 06-18-2020, 02:53 AM
VFR750's Avatar
It should be noted the stoptech pads are longer but narrower.
This means the rotor wear surface is narrower. And lighter. The od are identical at 282mm
The added radial height in the stock rotors is pretty useless because the squarish pad only makes partial contact with the rotor. Losing this contact area will have minimal to no impact. I am not concerned.
Old 06-18-2020, 03:33 AM
Bill Verburg's Avatar
Mike, If you can measure the distance from the axle center to the installed pad midline, that would be great
Bill Verburg
Old 06-18-2020, 03:58 AM
VFR750's Avatar
First pass measurement
Stoptech 235mm mid contact
Stock 226, (231mm accounting for the lack of inner surface contact area.)
235/226 = 4% larger torque arm
235/231 = 2% larger torque arm
Old 06-18-2020, 08:40 AM
VFR750's Avatar
Front left installed. Easy!
And the 6” wide Fuchs fit. That inner surface of the wheel is the fundamental problem with 15” and 16” Fuchs. That is why a spacer is needed to get enough room for the caliper to fit. This is what hurts bigger brake kits as the wheel has to be pushed outward to clear the ends of the caliper.
Mount bracket is pretty
Supplied brake line comes with integral mount that is compatible with the stock bilstein strut. Nice touch.
Old 06-19-2020, 03:00 AM
That is a NICE looking bit of kit. Track day ready...
I would consider de-badging them if possible. They’re quite proud of their logo.
Ken
1986 930 2016 R1200RS
Old 06-19-2020, 04:52 AM
VFR750's Avatar
Logo isn’t too bad, and hardly visible through the Fuchs windows. I’m ok with it.
I went with the anodized finish to be more in line with the stock dull metal look of the ATE calipers.
Anodized is also cheaper than the black, red, or yellow options. Marginal utility of painted calipers is $0.00 to me.
Old 06-19-2020, 04:57 AM
So no additional changes needed and you don't need to run a wheel spacer? It's nice to see more options available for us.
Old 06-19-2020, 05:38 AM
VFR750's Avatar
Correct
Bias is a little bit more on the front.
Master cylinder stays the same
6” wide Fuchs fit without spacers
Caveat: I am using the non-dust seal version of the STR-43 caliper. This is fine for me because this is a track car with dry weather street driving.
You will need a shallow spacer to fit the dust-seal version of the STR-43 caliper.
Old 06-19-2020, 05:54 AM
Originally Posted by VFR750 View Post
Correct
I'll be curious to hear your review after some track driving.
Old 06-19-2020, 05:58 AM
VFR750's Avatar
Lime rock on 6/25
Thompson on 6/27
Should be a valid test.
Old 06-19-2020, 06:10 AM
Lime rock on 6/25
Thompson on 6/27
What organizations are you running with?
Old 06-19-2020, 06:23 AM
VFR750's Avatar
PCA Connecticut valley 6/25
SCDA on 6/27
Old 06-19-2020, 06:40 AM
GaryR's Avatar
Send a message via ICQ to GaryR
What car are those mounted on? If an SC you may be able to add the Carrera restrictor to even out the F/R Bias, but Bill V. will know exactly what to do..
Gary R.
Old 06-19-2020, 08:18 AM
Would it be inappropriate to ask $? That's a very nice kit.
Old 06-19-2020, 11:00 AM
VFR750's Avatar
Yes an SC. I’m not worried about the small bias change. Tires, air pressure, camber, temperature all affect braking. 4% difference is not something I think is significant.
$1749. Some places have it for about the same.
Old 06-19-2020, 11:52 AM
I wanted to go see that event at limerock but it's closed to spectators.
Old 06-20-2020, 05:12 AM
