'73 911 T Targa
How do you remove the hazard light switch
I need to remove and re-install the headlight switch in my '73. It looks like it would be a whole lot easier if I got the hazard switch out of the way first. Since a replacement Hazard switch is $75, I'd like to see if I can get it out and back in without breaking it. Anybody know how?
I assume it's not the same than a 74? If by any chance it is you take it out towards you. first unplug the round connector, push the black tabs holding the switch to the dash from behind and you can pull it towards you
'73 911 T Targa
Based on the switch I found on PelicanParts, it looks like the same part, but I don’t see anything that looks like a round connector.
ROW '78 911 Targa
Wiring harness connector is round, slides onto the switch where all the terminals are.
Usually pretty tight fit, have to wiggle and pull it off. You can just make out the black plastic locking tab on the bottom right photo. (One on each side)
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 06-19-2020 at 04:03 PM.. |
Don´t have my car here so I had to steal some pictures from google, the round connector and the switch when fully connected look like one piece but they´re actually two, like Dennis said they´re difficult to pull off so you have to wiggle them.
You can barely see them starting to separate on the first picture, second picture shows what it looks like disconnected ![]()
"It's only temporary unless it works" 1974 911s turbo-look stock 2.7 engine "Dirty Martini" 1953 replica 550 spyder built from the ground up, EJ25 engine Speeduino ECU |
