Porsche really didn't leave too much on the table for these motors. They are well designed high performance machines which is what you were paying for. This is why its fairly costly to extract hp from them. Old school tricks are for small block Chevy's. :D
A great example is my 3.0 liter. In stock configuration, 3.0's make 180-190 hp. Mine makes about 250. Different induction, cams, pistons, exhaust, and other detail bits all added up to a substantial increase in power. |
I would argue that my SC 3l engine with 180 horses is proof that Porsche has had engineers to come up with as little performance as possible ..... :D 180hp on 3L ??? .... 30hp per cylinder (of 500cc) ??? how did they do it? To call a 3 L. 6 cyl. engine efficient, (ie an old one from 78!) it must have a minimum of 40hp per cyl. and- or 80hp per liter! Otherwise it should not sit in a "sports car" |
Cool suggestion! Let's just get some more of that stuff. For the most part, I "hit the wall" somewhere in my pursuit of entertainment on those dark winter nights ... I LOVE fiddling with things, and making old engines and cars better than originally intended from the factory. but I always end up with more power than I like to drive with (on the street that is). :) 2nd You can rest assured!... When my engine is built the way I want it, and it has been on the dyno for accurate mapping, and on the road for the last shake down. Then my gearbox will be disassembled, and all gear ratios will be calculated according to engine characteristics and my driving style! ;) |
We can in no way beat the game, against a turbo engine when it comes to hp! But there ARE other things that make an engine- and car, exciting! :D If you just want to be the fastest, buy an F-16. :cool: If you love a perfectly balanced engine, and the ability to use ALL of its potential without going into "Ridiculous speed", if you love to hear an engine breathe freely to 8000 rpm. then NA is for you! :D:D:D |
Best bang for the buck: Confirm the throttle(s) open 100%, that is, as far as the system allows.
With a helper at the gas pedal, observe the throttle stop(s) when the the loud pedal is floored. If misadjusted, power isn’t realized. Affects many. If okay, proceed with the above. Sherwood |
| All times are GMT -8. The time now is 06:08 PM. |
