Warren Hall Student
Name that Tool!
I came across this on German Ebay.
I have no idea what this is but that it can be used for Porsches. What is it?
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
Warren Hall Student
Another angle.
quite clearly it is a transmogifier that turns your little ol' 3.2 into a 3.8l Twin Turbo tuned monster. Worth every penny!
H '87 911 Euro |
Guest
Posts: n/a
Flux capacitor. No doubt.
Platinum Member
It repairs broken head studs..... bid quick & often.
Actually, looks like a compressed-air motor, having nothing to do with p-cars.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
You mean this thing?
I think it's the new voting machine for those morons down in Florida.
Professor M. Schiller Metro New York PCA America is successful not because of unions, but despite them. UNIONS DESTROY AMERICA www.CapitalistInstitute.org Last edited by Porsche911NYC; 04-15-2003 at 05:21 AM.. |
Its a two-cylinder steam engine, can't think of a useful application in a p-car..............
'71 E |
It's a P36 illudium explosive space modulatooooor.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
It's been looted from Sadaams palace.....buy it quick!!
__________________ Clay '80 SC coupe |
Senior Member
Nice little (homemade) steam engine. Beefy flywheel, too.
May (or may not) have been made by a craftsman in the Fatherland.
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
Small two-cylinders steam engine in Boxerform.Bohrung x Hub:12x14mm, Breite:9cm, Gesamthoehe:7cm.Mit compressed air tested, very good-compact, strong machine runs, because of the small mass ideally for steam boats to ca.70cm length.
Ken Copeland 70 GT6+ KC78784 70 Spit FDU84919 70 GT6+ KC81551 (Ok so I like 70s) 71 Porsche 911T 00 Chevy Pick UP |
Non Compos Mentis
That was the prototype of the analog anti lock braking system that Porsche experimented with on the 356 back in 1959.
disband
its a hamster power supply, ive seen one of these work before. you attach a gerbil friendly wheel (not shown) to the stainless input shaft. torque to 93 ft.lbs. (strange enough the same as lugs on a P-ride). then you pick yer vermin, a thorough bred short hair will work best. the teddy bear hamsters tend to get "too dam hot" do to lack of cooling capacity. a product called a "cool collar is rumored to help the long hair strain, i'd still prefer a short haired version. ifyou look close you can see the two oil lines that run from the unit to the carrera type cooling device (fan recommended in warmer climates), again not shown in this shot. just above the oil lines you will notice your power connectors, good for 220v or 110v depending on your application. the brass deal is merly a sump plate to access the valves on the unit that require adjustment ever 5 to 7k running hours. a tool called the island valve adjustment tool WILL be needed for this operation. get one of these while you can, there will be no group buys on this one due to limited availability currenly in the market. and oh yeah, the cut out on the side,,, its a cup holder.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Warren Hall Student
Answer:
Zweizylinder Damfmashine. (2-cylinder steam engine) Kaiser is the winner. The guy selling was also selling Porsche stuff and I thought it might be used for working on Porsches but I guess not.
