 69 911 handling/steering question So I'm new to the early 911's. Only had the car on the road for maybe the tenth time when I had to swerve abruptly left, then right to avoid hitting something in the road. The car felt loose so I experimented at about 50 mph moving the steering wheel quickly between say 11 and 1 o'clock. You can feel the body of the car rolling , as I would call it. When I did the same thing in my 89 911, it just darts in the direction you point it, and you don't feel this rolling/bobbing effect. Is this normal for an early 911, to have this effect I'm experiencing? I don't know if I need to check something on the car, or if this is just the way the earlier cars handle. Thanks!! |
 Pic of the car? These aren’t quite as stable feeling as the later cars but shouldn’t feel unsafe. A few things can affect this Tire profile Tire age Alignment Ride height Worn shocks Worn bushings Worn steering tie rods. No sway bars installed If the car is new to you have all the rubber inspected and alignment checked. |
 http://forums.pelicanparts.com/uploa...1593297731.jpg Car has no sway bars. Car was mechanically sorted after sitting 41 years. Tires and bushings and shocks and alignment are all good. Is it most likely the lack of sway bars? Thanks again!! |
 Does it brake in a straight line?  if so that eliminates some (not all) of the bushing issues and front torsion bar attachment point corrosion issues |
 Car drives and brakes in a straight line. No issues whatsoever. Only when doing the quick steering did it feel loose/wobbly. If wobbly is a word. |
 I can't speak to the wobble you are feeling but I do have a 68 and an 83. There is no comparison in handling. The 83 performs much better. The 68 has been restored but does not have sway bars. The geometry is also quite different which translates to a totally different feel. |
 It’s probably just a matter of technology advances. My 89 doesn’t do this. I think when car shows get going again, I need to catch a ride in another early 911 to compare. |
 Ok. I wanted to see the ride height. Looks ok.  The no sways will do it. It’s likely what you feel if your bushings and shocks and tires are good. When i got my 71. It was all fresh. No sways. Felt like a wet noodle compared to my 89. But man that amazing light steering feel. I promptly completely redid the suspension with sways (adjustable rear spring plates, sways, new digressive dampers, uprated torsions bars, turbo toe rods, etc) along with a full alignment and setup, Pirelli cn36 tires and lower ride height. Drives like a little badass now and hangs with the later cars in the canyons. Whatever you do don’t go too far! You don’t want it to feel like a later car. I feel like i nailed the balance with mine. It drives really really good. Before and after http://forums.pelicanparts.com/uploa...1593305188.jpg http://forums.pelicanparts.com/uploa...1593305188.jpg |
 how old are the susp. bushings? good may not mean what you think... same for engine & trans. mounts? shocks? |
 Thanks. That’s the struggle and with mine i kept the chassis mods period correct and in line with a firmer more sporting feel vs making it drive like a later car.  One easy and not too $ upgrade assuming you have the mount points on your a arms is the front sway. The rears require welding the factory mount points on. I think a front sway bar will help a lot with the lean. Of course you could just learn to embrace it and let that back end swing around and slide throwing It through corners :-) just stay on the gas! Enjoy the early car they are a lot of fun and i love the different feel and character they have. |
 Tires with soft sidewalls are a big handling issue. |
 [QUOTE=spyerx;10924865]Thanks. That’s the struggle and with mine i kept the chassis mods period correct and in line with a firmer more sporting feel vs making it drive like a later car.  One easy and not too $ upgrade assuming you have the mount points on your a arms is the front sway. The rears require welding the factory mount points on. I think a front sway bar will help a lot with the lean. My a arms are new. What do the mounting points you referred to look like. I think I would like a front sway bar |
 I love my Vredestiens . Check the air pressure in your tires 32-33 hot ? then try more or less. The ride height looks too low , which puts the roll center too low . That and the fact that you have no sway bars will cause excessive body roll . Look at the front control arms and notice the angle of the arm, is it level ? or pointing down to the outside , or pointing up to the outside . They should have a small angle drooping to the outside . Then when that is set correctly, the tie rods need to be set to dead level . Porsche calls for 108mm +- 5mm wheel center to T bar center front and 12mm +-5 on the rear . I hope this helps ,Icarp PS , sway bars for this car would only be about 15mm in diameter |
 Is your other car a Targa?  Unless the bushings are shot I would think it’s just the difference in cars. Targa, old torsion bars and bushings, no sway bars and 70 series tires is going to feel soft. Sent from my iPhone using Tapatalk |
 based on your responses, I think it has to be the lack of sway bars, tho I dunno how soft the sidewalls on those tires  are. if you can feel the degree of time lag in the roll, it might be very soft shocks - but it seems unlikely as you said they were new - they weren't "comfort" shocks were they? (Porsche offered a comfort pkg at one point - softer ride) and BTW, running a F. sway bar only will alter the under/over steer balance, so be aware - there is a chart on what does what so you don't have to think your way thru it |
 I agree with John Walker. I have an 88 on 16" rims. On the street it wears out rear tires 2x faster than fronts. I once replaced just the rears to save money (same tire model). The car became fairly dangerous-feeling for any quick steering inputs above 75MPH. I ended up replacing the fronts as well, the severity of the issue was drastically reduced. Just the extra tread made the difference. The car was set up for track, with -1.8 deg camber all around, so that didn't help - but it works the same for a street alignment as well, just the degree is different. 16" wheels and staggered widths should help your situation. |
 The shocks are not comfort. Does the vr rating give you a stronger sidewall as opposed to the r rated tires I have on now? I don't want to go to larger rims or too many mods, as I'm trying to keep the car a survivor. Perhaps front sway bar and new vr tires? |
 Bigger wheels may help your handling issues and, sway bars are not that hard to install? Those 14" wheels are kind of the red headed step child of Fuchs. Your car would look better with 15s IMHO. |
 You could try staggering tire pressure more if you're not already doing so.  More in the rear, little less in the front. If you switch tires, keep the fronts narrow and change to wider ones just in the rear. Try to pick summer performance tires - the bigger the tread blocks the better. The 14" might limit you there. If you don't plan many miles, so wear is not a major concern, you could get the rears shaved a bit. Basically you want the rear stiffer and the front softer, laterally. What is your driving experience? A few track days with an old 911 will be a total hoot, and will also help train your hands to make inputs at appropriate input speeds and coordinate properly with the throttle. This doesn't help the car, but it helps you, and you, along with your senses, reflexes, and feedback, are a big part of the system. |
 ^^^ Yea no need for tracking that car. Looks like a cool classic touring car.  Sent from my iPhone using Tapatalk |
 Thanks Derrick, this is my countryside cruiser. I won’t be tracking, but wouldn’t mind a bit more anti roll up front. |
 Is your car a 1969 E?  If so does it still have it's hydro pneumatic struts?  If not, what were they replaced with? |
 The issues you are asking about will be traced to the wheels, tires and sways(assuming that all else is at least nominal) '60 5.5 x14 w/ unspecified but likely 185/78 x14 tires and no sways vs a 6x16 205/55 & 8x16 225/50 The feel and response if the car is directly correlated to the pneumatic coefficient of the tires which is derived form the tire construction, geometry and pressures and from the wheel specs. A 185/78 or even 185/70 on a 5.5 x14 will have much more flexible sidewall and tread compared to either of the comparable wheel/tire sets on the '89, the 185 will run at a much higher slip angle( the whole tire twists and is distorted) and will as a result be capable of far lower inputs to the chassis vectors. What you will feel is a lazy, sloppy response compared to the later set ups, all else being equal, the '89 can be made sharper yet by judicious tuning. The other large influence is the sway bars which have a significant effect on chassis roll and thus on on camber gain or loss which also has a significant effect on grip and response. All 911s even your '89 have a lot of roll w/ a stock suspension compared to a truly sporting setup. a '69 T was designed as a comfortable tourer not as a sporting vehicle, the '89 is still a comfortable tourer but is also a much more capable sporting vehicle |
 Car drives straight, brakes straight, but if you're on the highway at speed and you make a sudden swerve for any reason, LOOK OUT!!!!You are likely to become a passenger. Thanks for all input!! |
 The easiest thing for you to do is to get a set of f/r sway-bars, 15/15 from a '72-73 would help tame body roll a lot, Back in the day we added them to bar less T's , the better kits back then were from H&H Carrera but that was 50yrs ago |
 I have a 1970 T with comfort package I am running 185 75 14 Tiger Paws Tire psi F 29 rear 31 I added a 15mm through the frame sway bar. It changed the car. Car is stable at high speeds, but front end gets light feeling. Car does blow around on windy days. I had the problems you are talking about. Went to a really good alignment that knows Porsches. Solved the problem. Your latter 911 is heavier and has lot more rubber on the ground. You can't compare them. Also check the age of your tires. Bernie |
 Thanks guys, think I'll start with higher tire pressure. No improvement's I'll go to front sway bar. Does anyone know if the vr rating gets you a stronger sidewall over an r rating?  Latunabernie, do your tiger paws have a r or vr rating? Thanks guys |
 Hi Robert, The Uniroyal tiger paws are a M&S all season tire. 89S rating range B 4 ply. When I wear these out I will be going to the new classic Pirelli. 14" tires have very limited choices. unless you want trailer tires. My car came with 14" Fuchs. I plan on keeping them. Bernie |
 What tire size are you going with on the classic Pirelli? When I look up the correct size for my car, 185/70/14 the only tire that is sufficient is the Vredestein sprint classic. All five of my 14" fuchs are original and matching date stamped. I don't want to change my rim sizes. |
 The correct (original) size for your car is NOT 185/70-14. It was 185HR14, which in today's nomenclature is equivalent to 185/80-14. There are only three tires in the correct size that are (or claim to be) for use on classic sports cars. The original size of 185HR14 is available in the Vredstein Sprint Classic (available from several vendors), or the Michelin MXV-P (available from Coker). I'm not crazy about either one as being a true performance tire, but of those 2 I'd go with the Michelin. I've heard too many people complain about soft sidewalls and sloppy handling with the Vredsteins. There is now an additional choice - 185/80HR14 in the Dunlop Sport Classic (available from Coker). I've not heard/seen many reports on this tire yet, but the few I have heard have been good. The Dunlop is actually made in Europe by Goodyear, and the tread looks a whole lot like the old Eagle NCT/Eagle GT/Wingfoot tires from the late '70s and early '80s. It might be a good choice. |
 There is a lot more to tire suitability for a particular purpose than just size or specs or sidewall height/stiffness. You need to look at true, performance rated sports car tires. Which are admittedly hard to find in a suitable size for the 14" wheels. |
 One additional thought - Remember that the 14" wheel option was sold as part of the Comfort package. So even the best of performance tires that were available back in the day were not going to handle as well as the 15" options - the 14" were supposed to be softer. I totally understand wanting to retain the original 14" wheels, which is why I'd strongly consider the new Dunlop in size 185/80HR14 if I were you. But due to the small wheel size, and the "comfort" aspect of that, you might be happier with 15" wheels and tires. |
| All times are GMT -8. The time now is 05:58 AM. |
