Hood Ground Straps
![]() One of these on each hood hinge. Are they to ground the AC condenser? My AC system is removed. Can I remove both of these ground straps? Thanks |
My never had AC car has these ground straps. Must be a reason for it.
72 914-6 GT Conversion 2.7 82 911 SC Coupe 78 SC Targa Hotrod |
My SWAG, though I'm no engineer on this subject, is that it prevents a static charge from developing as the air goes through the engine lid air intake grill
Formerly known as Syzygy
I could see this being a possibility. You can even get static build up with a vacuum cleaner for the same reason as well, so yeah, maybe. It is interesting they felt the need to electrically bond the engine lid. Never seen that on any other vehicle.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
I am a retired (German) engineer and I removed the hood grounding straps because I think they are dumb.... Who knows what those Porsche engineers were thinking? Just look at the heater controls!
1988 Carrera coupe 1966 250 Ducati 2015 VW Golf TDI gone because Dieselgate! 2021 VW Golf TSI 2014 Ninja 300 |
Senior Advisor
ground strap for the hood light, power on top in the pic
08 Cayenne Turbo |
I'm quite certain that's how that light gets its ground, but the ground strap is waaay overkill for just that little bulb.
How about radio interference, noise. If the lid was not grounded and developed a charge. ???
Rob |
Maybe for the rear window wiper and rear window heater. Mine is a cabriolet so I don’t have either. I will disconnect them and see if the hood light still works. |
Some have a windscreen wiper for the rear window, I can only assume that it is grounding for that ?
__________________ 1985 Carrera 3.2 |
Disconnected and removed both straps. Engine compartment light still shines bright.
Early 911s have license plate lights in the engine lid and later models have motorized spoilers. All electrical loads need a good ground. Yeah, the lid, bolts, nuts, washers and hinges are metal, but it’s better to have a direct, clean ground connection instead of relying on electrons to easily pass through metal corrosion, paint, etc.
Remove the large ground strap on the transmission mount and see if the weight savings will allow the starter motor to crank at full voltage. Sherwood Last edited by 911pcars; 07-07-2020 at 11:09 AM.. |
Location: behind the redwood curtain, (humboldt county) california
Maybe not...
I once heard of a guy forgetting the main engine ground and when he hit the starter, it cranked kind of slow and the gas pedal went to the floor. It seems that that big blast of starting electricity found the least resistance path was through the throttle linkage and it melted through - sometimes it is difficult to tell what is going to happen. Chris |
With major market cars I take the attitude that if the engineers were able to convince the bean counters that a particular part was important enough to spend an extra $1, then there is a valid reason for the part. Not so much on the Porsche. But still, the straps weigh almost nothing, so I'll keep 'em.
1990 964 Coupe 1986 Carrera 3.2 Targa |
Registered Minimalist
Another thread like this floating around. I believe it was radio interference was the main reason. Blah blah Faraday shield.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
My philosophy has always ground everything in multiple places. No such thing as too good or too many grounds, but a LOT of issues can pop up with a poor ground. Problems that will make you think a car is haunted.
That ground strap can't weigh much. Unless you are building a dedicated track car and you are a top professional level driver, you will never notice the difference. You should NOT be driving at 9/10th or 10/10th on the street anyway.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
These are braided lines bridging both 3.2 intake halves to ensure a good ground for the injector rails and etc.
![]() Sherwood |
