Clogged filter? Junk in the carbs? Locked timing shouldn't cause bucking as described.
Matt B
'73 911E
Old 08-30-2020, 11:15 PM
Walt.
Changed fuel pump out and got pressure perfect. Can adjust a range of pressure so now know it’s working properly.
Tried your advice with the dizzy. Bingo!!!
Have dizzy out and believe it needs some love. Up and down play seems excessive. 1.5-2mm. Back to the bench and thanks!!!
Old 08-31-2020, 07:55 AM
Under the radar
Trackrash's Avatar
Might be worth installing an air fuel meter. Assuming you have good ignition and advance the AF can show what may be going on with the carbs.
Gordon
'71 911 Coupe 3,0L outlawed
Old 08-31-2020, 11:58 AM
Thanks Gordon. Like that idea.
Old 08-31-2020, 01:10 PM
I just purchased a duel AFR meter from Innovative for my fresh 2.8. Price was decent.
Old 08-31-2020, 03:12 PM
Does it have to be install with a O2 bung or does it have a tailpipe probe?
Old 08-31-2020, 03:22 PM
Comes with bungs. You have to have them welded on. I had Brian at M&K weld them on when I ordered my headers from him. I run carbs, so would like to know whats going on.
Old 08-31-2020, 07:09 PM
Here's what kit comes with
Old 08-31-2020, 07:13 PM
Thanks definitely looks like something for this winter. Along with the other projects. Ha ha!!
Old 09-01-2020, 05:30 AM
