rollandburn's Avatar
Front tires bald after 4000 miles
Hi, I’m just on my way back from a trip out east (4500 kms total) and am noticing the car is tracking over highway grooves, dodging left and right. Before leaving on the trip the car had 2000kms on the following work...
: last fall I put in all new polybronze ER bushings, sport bilsteins w/ raised spindles, turbo tie rods, tarrett sway bars, rebuilt steering rack, new bridgestones summer rubber on 16 x 6/7’s. Brought the car to a ‘reputable’ 911 shop who buttoned everything up and had the alignment done. Everything seemed great, felt tight buzzing around the city.... felt ready to head out to the coast on a long trip.
During the final legs of the return trip I was pretty sure something was amiss with the front on account of the steering feel so I inspected the tires and am unhappy to report the inside of both front tires are burnt right off... no tread. Looks almost new on the outside of each tire. It’s almost like she was snow plowing all the way down the highway. With the naked eye it sure looks like there is camber on both front wheels with the top of the wheels noticeably inboard from the bottom. Rear tires are fine.
I’m curious, do all of the suspension mods mentioned above also come with alignment compromises where one should expect to wear through fronts this fast? I thought with the raised spindles alignment should not require compromise at euro height. Add to that the lack of any significant camber required for 6” Fuchs (as far as I’m aware).
On the bright side I just got new 16x 8” and 9” Fuchs and will need new rubber anyway... but I suppose I am, again, second guessing even bothering to take my car back to this ‘reputable’ 911 specialist. Just not sure if this is normal, or something the shop just didn’t get right (ie. with alignment).
If it isn’t normal, what’s the best approach if I do take it back to the shop? Any advice appreciated.
Ps. I just looked at the invoice and there is no alignment listed... however it had to have been done, they knew all suspension was new.
Pps. Tire pressures were/are 2.5 bar in the rear, 2.0 in the front.
rollandburn1985 911 Carrera
Old 09-12-2018, 12:46 PM
I would rather be driving
jpnovak's Avatar
NO, suspension mods do not specifically induce tire wear. What are your alignment settings?
Typically camber doesn't wear out tires like you describe. Incorrect toe settings will. You are right, its a snow plow effect.
If you don't see it on the invoice along with numbers then it wasn't done.
Old 09-12-2018, 12:53 PM
Camber and toe #'s.
Maybe a toe issue?
Isn't darting an effect of to much toe out?
Old 09-12-2018, 12:54 PM
Some pics... probably hard to see the wheel angle.
I don’t have alignment numbers unfortunately, no paperwork. Invoice shows all other work though. Grrrr.
Anyone know of a REALLY reputable shop in Toronto?
Sent from my iPhone using Tapatalk Pro
Old 09-12-2018, 01:12 PM
Hilbilly Deluxe
emcon5's Avatar
My guess, toe.
82 911SC Coupe
GTI Cup #43
Old 09-12-2018, 01:15 PM
old man neri's Avatar
Sometimes all it takes is one pothole to throw the alignment way off. It may have nothing to do with your suspension work.
Old 09-12-2018, 01:58 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Question.
Off topic, but what is this?
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 09-12-2018, 02:04 PM
Gerry
Por-15
Old 09-12-2018, 02:09 PM
I was thinking the same... the roads between Toronto and Halifax aren’t exactly baby bottoms and the Cabot Trail is absolutely brutal in places. Maybe a good jarring knocked it out of alignment. What made me dismiss this possibility, or not give it much weight, is the fact both front tires are equally burnt on the insides... I’m envisioning a pothole on one side though. Do you think the toe could get knocked outwards equally with a good smack over a raised bump perpendicular to the direction of travel? Not like a speed bump at 120... but the same idea. (Point I’m making is I didn’t hit one side hard, but many times both wheels would hit raised areas going across the Road with an uncomfortable thump at speed).
Old 09-12-2018, 02:16 PM
you can do a quick check of toe simply with a tape measure just measure to that center tread line on the tire in the front and back as high off the ground as you can get. It will give you a pretty accurate idea of whats going on. Alignment machines can be real finicky and often put out false readings.
Old 09-12-2018, 02:18 PM
I think I know what you mean... the widths between fl/fr tires and rl/rr tires should be the same. If a measurable difference is found that would mean a toe in/our issue. Not sure why but I just assumed the rear was wider and didn’t consider that measurement... thanks.
Old 09-12-2018, 02:27 PM
a bit off topic, but aren't you going to run into a similar issue when you try putting 16x8 wheels up front -- seems the general advice to minimize rubbing the fender rim when running wider front wheels is to increase camber (bring the top of the tire closer to center), which will put more weight on the inside edge of the front tires . . . .
Old 09-12-2018, 02:34 PM
Doesn't matter which toe is out and by how much. Doesn't have to be equal. You will center the toes with the steering wheel to go in a straight line. Does that make sense?
Ah yes, NS roads. I know all about them. Maybe a good bump settle something in your suspension that just hadn't seated quite right.
Anyways, my advice would be to go to an alignment shop and see what the toe is. I'm not a suspension expert though.
I hope you enjoyed the Cabot Trail.
Old 09-12-2018, 09:34 PM
Under the radar
Trackrash's Avatar
+1 Tape measures don't lie.
Then grab each wheel at the top and see if they can be moved, any play. Then grab the front and rear of the tire, wiggle back and forth. Should be no play.
Then jack up the car and repeat. Lots of things can come loose, so do a through check.
Gordon
'71 911 Coupe 3,0L outlawed
Old 09-12-2018, 09:41 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 Tape Measure it.
Get a wheel chock, use duct tape, place it about 4" from the ground, tape hook upside down and place in a tread groove that is deep enough then measure the opposing tread groove. Do front and back, you will see.
Definitely too much toe in, man those tyres are not cheap either :-(
'85 Carrera Targa
PCA/POC
Old 09-13-2018, 01:53 AM
RDM RDM is online now
Coram Deo
RDM's Avatar
I think what he means (and what I would mean) when checking front toe would be to measure front of front left tire to front of front right tire, then back of front left tire to back of the front right tire. The difference of those two measurements would be your front toe.
This measurement is not affected by different wheel widths front/back. You can repeat this measurement for the rear wheels to find rear toe, but that doesn't sound like where the problem is.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio
Old 09-13-2018, 03:42 AM
shh-the robot is sleeping
How far are you from the shop that did the work? I would get them to look at it and the tires.
'88 911 Coupe, 69k miles
Old 09-13-2018, 04:32 AM
LJ851's Avatar
Too much toe out is the problem here.
If it were too much toe in it would wear the outside edge of the tires and would track reasonably well.
Old 09-13-2018, 04:43 AM
If I understand correctly 951 16x8 Fuchs fit well under Carrera fenders with a roll of the lip, and around -1 camber (something you want). It sounds like the current issue has to do with toe misalignment which is much harder on tires (something you don’t want). Wear from neg camber would be less, expected, and intentional, whereas the current toe wear is unexpected, definitely due to a problem, and happening ridiculously fast. That’s how I’m looking at it, but suppose you could see them as similar issues.
Old 09-13-2018, 06:11 AM
Thanks for all the feed back. After arriving home last night I noticed the drivers side front skirt was nearly touching the ground where I was parked to unload. That side was much lower than the passenger side, could barely get my hand on top of the tire between the wheel well. I used two hands in the arch of the wheel well and pulled up gently... the car rose. Push down on the fender, it dropped back to the low position. Tried the same on the passenger side, didn’t budge. Today I’ll go for a drive back to the shop and see what he says.
Old 09-13-2018, 06:20 AM
