Rennch on YouTube
ENGINE GURUS! Help Me Compare A Stock SC Motor To....
Doing a little research for an upcoming video.
I don't know engines REALLY well, so I'm curious how these specs differ from a stock SC 3.0 engine: 6 Cylinder, 2999cc boxer engine 4-valve, quad camshaft aluminium cylinder heads Open-deck aluminium cylinder block Bore: 89.2mm Stroke: 80mm Rod Length: 131.5mm 10.7: Compression ratio Dual timing chain system Coil on plug-ignition system Plastic intake manifold Drive-by wire electronic throttle body 76mm OD3 exhaust-port cylinder head design Variable lift and variable timing intake camshaft (ALVS and AVCS) much like Honda’s iVtec system. Can you help me identify the differences, and/or point me towards a similar spec sheet for the 3.0 SC engine? Thanks!
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
El Duderino
6 Cylinder, 2999cc boxer engine <-- SC is a 6-cylinder boxer 3.0L 4-valve, quad camshaft <-- SC is 2-valves per cylinder & 2 camshafts aluminium cylinder heads <-- pretty sure this is true for the SC Open-deck aluminium cylinder block <-- ??? Bore: 89.2mm <-- 3.54 in/90 mm Stroke: 80mm <-- 2.77 in/70.4 mm Rod Length: 131.5mm <-- ??? 10.7: Compression ratio <-- I think US is 8.5:1? and Euro version is 9.3:1 Dual timing chain system <-- two chains Coil on plug-ignition system.<-- SC uses captive discharge ignition, single coil and distributor to fire all cylinders Plastic intake manifold <-- um, almost everything is these days? Drive-by wire electronic throttle body <-- CIS fuel injection has throttle plate 76mm OD3 exhaust-port cylinder head design <-- ??? Variable lift and variable timing intake camshaft (ALVS and AVCS) much like Honda’s iVtec system. <-- no variable camshaft, cam profile is what it is One of the main differences you didn't mention sounds like your other car uses EFI and the SC used CIS.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. Last edited by tirwin; 07-15-2020 at 03:46 PM.. |
Rennch on YouTube
Literally Everything I needed. Thanks Tim.
El Duderino
Sure, no problem. Go back and look at my post again. I made a mistake and corrected it.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
Open-deck aluminium cylinder block < Pretty sure this is describing the water jacket design on a water cooler engine.
Open Deck ![]() Closed Deck
SC rod length is 127.8mm
SC CIS has aluminum intake tubes and a plastic plenum. SC is air cooled, so the cylinders have fins, not open or closed deck as with liquid cooled engines. |
3.0 is 95mm bore
127mm rod length The rest looks good Tony |
Rescuer of old cars
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
What you list is not an SC 3.0, more like a more modern water cooled Boxter
Bruce |
Rennch on YouTube
We haaaaaave a winnerrrrrrr ![]() ![]() ![]() Sent from my iPhone using Tapatalk
Rennch on YouTube
One thing I didn't ask, but it's worth knowing: SC engine 462lbs, Subaru EZ30 397 lbs.
I would rather be driving
And for EZ30 you have power output of:
180 kW 240 hp; 240 PS @ 6,600 RPM[21][33] 297 N⋅m 219 lb⋅ft @ 4,200 RPM[33][34] If you boost it then typical limitations are about 340Hp. https://www.possumbournemotorsport.com/ez30-info Boosted 3.0 911SC could be above 500hp. Each requires money and skill to build for high power and address weak points and cooling. I looked into this for my old Suby powered 914.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
And then the weight is offset by the cooling system and coolant. But the distribution of weight can be favorable depending on locations and mounting points.
Rennch on YouTube
Specs say it takes a gallon of coolant, or 8 lbs. and about 5 less quarts of oil than a Porsche. So it’s a wash. Sent from my iPhone using Tapatalk
I think he was talking about the radiator and hoses. I don't suppose those weigh more than 20 or 30 lbs?
Looks like fun. Sent from my Nokia 7.1 using Tapatalk |
I didn’t realize it was an advert , I thought it was a technical question
Rennch on YouTube
It is. What am I supposed to be selling?
Rennch on YouTube
Either way, should be fun indeed!
Early SCs CR was 8.5:1. Later US 9.3, Euro 9.8.
4 valve water cooled engines with knock sensors and ECUs seem able to run a point or so higher on the same octane fuel. There are nominally stock SCs out there which appear to put out 240 flywheel HP (estimated from RWHP figures, as not many shops have an engine dyno). How is a good question. |
Kudos to you. Can’t wait to hear how this drives.
Brian Miller - Scottsdale, AZ 1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S |
