billh1963's Avatar
Removing rear brake caliper... What tool works best on bottom 19mm bolt?
Replacing calipers with new PMB units and am struggling with the bottom bolts on the rear calipers. My 1/2" drive 19mm socket won't fit and a 3/8" drive isn't robust enough. I don't think a 19mm wrench will give me the leverage I need. What are you using?
Thank you
Old 02-02-2016, 04:27 PM
1980 911 SC
When I have a wrench/socket that gets into the space but needs more leverage I find a piece of pipe 12-18" long that will fit over the handle and use it as leverage. I replaced my calipers a few years back but can't remember what was involved.
Life's a Beach
Old 02-02-2016, 04:38 PM
cashman's Avatar
I use a 3/8 socket with a small conduit pipe extension about 8"long. Never had a problem.
1989 911 Carrera Cab
25th Anniversary Edition
Euro Pre-Muffler, SW Chip
There's nothing better than: Listening to "Going Down the Road Feeling Bad" ,as I, "Go Down the Road Feeling Bad"
Old 02-02-2016, 04:39 PM
19mm box end wrench. One that's not clunky.
206 637 4071
Old 02-02-2016, 04:56 PM
6 cylinder symphony
19 mm Craftsman cross force wrench. Allows you to get weight on the wrench easier.
I just did this a few weeks ago, and it worked great.
'84 3.2 Targa
'89 964 Coupe
"What do you mean NEXT project?" - my wife
Old 02-02-2016, 04:58 PM
I used a 19mm box wrench as well, but had to soak the bolt overnight with PB Blaster and still had to whack the wrench with a 3lb hammer.
Old 02-02-2016, 05:00 PM
billh1963's Avatar
Guess I'll have to jack the car up a little higher so I can use the pipe extension or other tricks. I'll ray the pipe extension first.
Thank you for the quick replies
Member 911 Anonymous
DRACO A5OG's Avatar
+1 box wrench and cheater box wrench for leverage
When you torque it don't go crazy
'85 Carrera Targa
PCA/POC
Old 02-02-2016, 05:28 PM
Bulldog9's Avatar
I used a 19mm 3/8 socket with a 12" breaker bar and pipe for leverage, once I broke it loose maybe 2 turns to expose threads, I sprayed Liquid Wrench (0r equiv) on the threads and while it sat broke loose the other side and did the same. Then went in with a shorti 19MM and finished off. 3 beer job... lol
1976 Porsche 912E http://www.912bbs.org/vb/showthread.php?43391-770-Update
1989 Porsche 944 S2
2020 Mustang Bullitt
Buncha Moto Guzzi Motorcycles
Old 02-02-2016, 06:50 PM
sugarwood's Avatar
I got the lower caliper bolt off using 3/8" ratchet with 19mm socket.
Had to use a pipe on the ratchet to break it loose.
Then I just used a ratcheting wrench to spin it off (a few degrees at a time)
1986 Bosch Icon Wipers coupe.
Old 02-02-2016, 07:04 PM
This is what I use. We Brits call it a combined ring spanner/open-ended spanner (is this what you guys call a box wrench?). I use the ring-spanner end; it's offset so when I get it on it sticks out away from the caliper and then holding it in the direction to undo the bolt so that there is no slack I give it a good whack with the hammer (like JRSIII).
this second photo shows offset
1959 Bristol 406 (bought in 1972; sold in 1977)
1966 Porsche 2.0 coupe (bought in 1977; sold 1981)
1978 Porsche SC coupe (bought in 1993)
Old 02-03-2016, 03:31 AM
KNS KNS is offline
Yep.
Kurt
Old 02-03-2016, 07:20 AM
JSV798 has nailed it. A "ring spanner" and a five pound hand sledge are my go-to tools for this operation.
Been doing it for years. I just don't have time for all that soaking and stuff, LOL.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 02-03-2016, 08:26 AM
Put the top bolt back in and get it just short of tight. Then, once you crack the bottom bolt loose (using the afore mentioned wrench), it won't have weight on it, and you can slowly get the bolt worked out with your fingers. It's slow, but faster than using a wrench 1/6 turn at a time. Or, remove top bolt, crack bottom bolt, and then sue second hand to support the weight of the caliper so the bottom bolt can be backed out with fingers.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 02-03-2016, 08:44 AM
billh1963's Avatar
Once I get it loose it won't be a problem using the 3/8" drive and socket for removal. Getting in there for the leverage has been the issue. Just bought an extended length 19mm box end wrench (American version of ring spanner ) that should do the trick!
Old 02-03-2016, 10:17 AM
VFR750's Avatar
Originally Posted by kns View Post
yep.
+1
Old 02-03-2016, 11:44 AM
Use two combination wrenches of roughly the same size.
This photo was taken with the wrenches upside down (tighten not loosen) but you get the idea from this. I use this trick in the field often where you encounter a stubborn bolt and a cheater pipe is a long distance away. Works with Kroil very well.
Old 02-03-2016, 12:21 PM
You may want to double check on that strategy to remove it with a 3/8 socket wrench once it's broken loose. It's a fairly long bolt and you might end up backing the head of the socket wrench into the trailing arm and might not be able to get the wrench off. I bought a 19mm ratcheting combo wrench for this very purpose and it worked great. I used the regular 19mm combo wrench and hammer to break it loose, then the ratcheting wrench to remove it.
Old 02-03-2016, 04:43 PM
SoCalSK8r's Avatar
I used 2 box wrenches just the same as Rusnak and it worked fine.
‘84 Carrera, heavily modded
Please follow me @chopped_up_fitness
Old 02-03-2016, 04:51 PM
billh1963's Avatar
Long 19mm wrench and hammer worked just fine. :-)
Old 02-03-2016, 06:19 PM
