Under the radar
Trackrash's Avatar
Shift Fork Jig for 915s FREE
For you hardcore DIY guys here is the 915 Shift Fork Jig pattern. This file is in the STL format. I confirmed it will work in a 3D printer.
https://drive.google.com/file/d/1anvc7IQeZjnWq6Kmcosa5HHxMKN6UTxH/view?usp=sharing
This file can be downloaded and used to print your own jig. The use of this file is for personal use. No commercial use or sale of this file is permitted.
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-29-2019, 09:54 AM
Under the radar
Trackrash's Avatar
Analog version
For you analog guys...
The tolerance is + - 0.125mm.
If any of my dimensions is off, let me know and I'll make the change. I'm not sure why Autocad listed four decimals in my layout.
Gordon
Old 04-29-2019, 09:57 AM
Perpetual Reassembler
2jmotorsports's Avatar
Thanks Gordon for sharing the knowledge!
Jose - 1983 911SC Coupe
Instagram: @joe_engineer
911 D I Y Blog: joe-engineer d o t c o m
D I Y Vids: https://www.youtube.com/joeengineer
Old 04-29-2019, 10:11 AM
nb6179505's Avatar
Umm what does it do and how do you apply it?
Sent from my Pixel 2 using Tapatalk
Old 04-29-2019, 02:17 PM
Under the radar
Trackrash's Avatar
The black tool in the screen cap is used to align and allow the shift forks to be properly adjusted when repairing a 915 transmission.
I have created a 3D model that can be used to print the tool. The file can be downloaded from the link.
Gordon
Old 04-29-2019, 03:42 PM
Harpo's Avatar
Awesome, do you know if this is available as a step file so I can have it cut out with a water jet?
Old 04-29-2019, 03:53 PM
Do you think if it was accurately made from wood, would it would work? Rob
Old 04-29-2019, 04:01 PM
Under the radar
Trackrash's Avatar
I'm not familiar with what a water jet would need for a file. I can post a DXF file if that helps. The STL file works in the control for a 3D printer. Let me know what format you need, and I'll see if I can output it.
I don't see why not. A good hard wood should work fine.
I made one for my 901 out of 1/4" thick aluminum and it worked great.
Gordon
Old 04-29-2019, 04:47 PM
djpateman's Avatar
That is a setting that can be changed. Thanks for the files.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 04-30-2019, 02:38 PM
For 3D, a STEP or IGES would be pretty universal. For 2D a DXF should be fine.
Old 04-30-2019, 03:02 PM
(man/dude)
Jonny042's Avatar
I just bought a nice looking solid aluminum one on ebay for $79 shipped - now I can check the dimensions of it before I take the trans apart thanks!
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 04-30-2019, 05:30 PM
Under the radar
Trackrash's Avatar
Yea, I changed UNITS to metric from architectural and specified 0.000, but forgot to change the precision in DIMSTYLE. Oh well.
I don't have a way to export or convert to the STEP format. I'll post a 3D DXF later when I get a chance. Autocad exports the DXF in 3D wireframe.
Cool. You can check my measurements. I used a caliper on the plastic jig I bought years ago, so I may not have as accurate dimensions as I would like. I did do a 3D print from my STL and it looks to be as close as what can be achieved using that method.
Gordon
Old 05-01-2019, 07:44 AM
Thanks!
www.ahhgaragetime.com
Old 05-01-2019, 11:09 AM
Gordon, the old plastic jigs were notoriously inaccurate...
Inaccuracy of aftermarket 915 shift rod holder tool
Instead of checking the measurements against other jigs, compare them instead to the bores of a 915 case.
Jon B.
Vista, CA
Old 05-01-2019, 11:47 AM
Under the radar
Trackrash's Avatar
If only I had one laying around.
My hope is that if someone has more accurate measurements they can forward them to me and I can make the changes. FWIW, the plastic one I have served its purpose.
Gordon
Old 05-01-2019, 11:56 AM
Hi Gordon,
do you have the measures for analog guys of Shift Fork 901 ?
Marco
Old 07-22-2020, 01:11 AM
Diss Member
Quicksilver's Avatar
. . . I'm not sure why Autocad listed four decimals in my layout.
In AutoCAD the decimal places of dimensions doesn't come from the obvious Units commands. It is buried in the dimensions style in a sub-menu/option that isn't obvious. You've got to spend a couple minutes clicking around in there.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 07-22-2020, 01:27 AM
Under the radar
Trackrash's Avatar
OK. I made this jig from 3/16" aluminum plate by tracing the pattern from the intermediate plate on my old 911 trans. So I cannot guarantee the dimensions are perfect. I did use it successfully several times. Dimensions are in mm.
Gordon
Old 07-22-2020, 10:17 AM
Thank you very much Gordon 👍
Old 07-22-2020, 11:19 PM
