Under the radar
Shift Fork Jig for 915s FREE
For you hardcore DIY guys here is the 915 Shift Fork Jig pattern. This file is in the STL format. I confirmed it will work in a 3D printer.
https://drive.google.com/file/d/1anvc7IQeZjnWq6Kmcosa5HHxMKN6UTxH/view?usp=sharing This file can be downloaded and used to print your own jig. The use of this file is for personal use. No commercial use or sale of this file is permitted.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 04-29-2019 at 05:52 PM.. |
Under the radar
Analog version
For you analog guys...
![]() The tolerance is + - 0.125mm. If any of my dimensions is off, let me know and I'll make the change. I'm not sure why Autocad listed four decimals in my layout.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 04-29-2019 at 05:49 PM.. |
Perpetual Reassembler
Thanks Gordon for sharing the knowledge!
Jose - 1983 911SC Coupe Instagram: @joe_engineer 911 D I Y Blog: joe-engineer d o t c o m D I Y Vids: https://www.youtube.com/joeengineer |
Umm what does it do and how do you apply it?
Sent from my Pixel 2 using Tapatalk |
Under the radar
The black tool in the screen cap is used to align and allow the shift forks to be properly adjusted when repairing a 915 transmission.
I have created a 3D model that can be used to print the tool. The file can be downloaded from the link.
Awesome, do you know if this is available as a step file so I can have it cut out with a water jet?
Thanks David |
Do you think if it was accurately made from wood, would it would work? Rob
Under the radar
I made one for my 901 out of 1/4" thick aluminum and it worked great.
That is a setting that can be changed. Thanks for the files.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
For 3D, a STEP or IGES would be pretty universal. For 2D a DXF should be fine.
(man/dude)
I just bought a nice looking solid aluminum one on ebay for $79 shipped - now I can check the dimensions of it before I take the trans apart thanks!
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
Under the radar
Yea, I changed UNITS to metric from architectural and specified 0.000, but forgot to change the precision in DIMSTYLE. Oh well.
Cool. You can check my measurements. I used a caliper on the plastic jig I bought years ago, so I may not have as accurate dimensions as I would like. I did do a 3D print from my STL and it looks to be as close as what can be achieved using that method.
Thanks!
www.ahhgaragetime.com |
Inaccuracy of aftermarket 915 shift rod holder tool Instead of checking the measurements against other jigs, compare them instead to the bores of a 915 case.
Jon B. Vista, CA |
Under the radar
My hope is that if someone has more accurate measurements they can forward them to me and I can make the changes. FWIW, the plastic one I have served its purpose.
Hi Gordon,
do you have the measures for analog guys of Shift Fork 901 ? Marco |
Diss Member
In AutoCAD the decimal places of dimensions doesn't come from the obvious Units commands. It is buried in the dimensions style in a sub-menu/option that isn't obvious. You've got to spend a couple minutes clicking around in there.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Under the radar
OK. I made this jig from 3/16" aluminum plate by tracing the pattern from the intermediate plate on my old 911 trans. So I cannot guarantee the dimensions are perfect. I did use it successfully several times. Dimensions are in mm.
Thank you very much Gordon 👍
