Rough idle
1985 3.2 Cab with 46,000k
Replaced the Cap, Rotor, Wires, Plugs and O2 Sensor. Car runs 100% better but idle still hunts, not bad but not smooth.
Any suggestions ? Thanks again Ken
Old 07-27-2020, 10:32 AM
proporsche's Avatar
when you say hunts..it goes up and down on idle..right..Does it only cold or even when warm?
Ivan
i would suggest adjusting the fuel mix---do you have an aircondition?
1985 911 with original 502 191 miles...808 198 km
Old 07-27-2020, 11:10 AM
- rough idle is a better description than hunting idle
- it does have air but I haven’t used it
Leaning toward a Fuel Injection Idle Module or vacuum leak ?
Old 07-27-2020, 12:02 PM
911 enthusiast
tmadden2's Avatar
Franny's video on the idle control valve can run you through some typical cold idle conditions, what vacuum lines do what, and how to clean the ICV.
https://youtu.be/MRZG-s_55CU
Old 07-27-2020, 12:31 PM
Tighten down all the head runner bolts. I bet some are loose. Easy thing to try. Helped me years ago. Loose bolts will make tough idle.
Old 07-27-2020, 01:01 PM
proporsche's Avatar
it is possible but i doubt the intake manifold is loose..The engine has only 46K...miles
The reason i have asked for you air is.If you put the engine on and let it sit on idle put on your a/c.Then step on the gas and let it go back to idle if it dies or try to die your fuel mixture is too rich..
Ivan
yes, check as suggested into cleaning your idle control valve...since it is not hunting idle problem...
Old 07-27-2020, 01:04 PM
Thanks... How would I clean the Idle Control Valve, take it off and spray it with Carburetor Cleaner ?
Old 07-27-2020, 01:19 PM
Yep
Old 07-27-2020, 01:41 PM
Many different car makes used the same idle control valve. Find one at a salvage yard! I did.
Old 07-27-2020, 02:17 PM
Took off and cleaned the idle control valve which made no difference in the idle. Placed a hose on the housing and listened for movement, heard none.
- If i removed one of the hoses attached to the unit will would i see movement ?
- Does the unit work all the time ?
- Any suggestions on how i can test the valve ?
- If it needs replaced, do i buy a used or look for a new unit?
Old 07-30-2020, 06:35 AM
proporsche's Avatar
Ken put your ignition on(do not start the engine) go and put you hand on the idle c.v. it should purr like a kitten -humming---if it does it works..
Ivan
Old 07-30-2020, 06:44 AM
It’s not... Thanks
Old 07-30-2020, 06:54 AM
proporsche's Avatar
i suppose you have it plugged in , the el. connector ,right?
Old 07-30-2020, 06:55 AM
Yes... What unit would you suggest i replace it with new, used, Bosch $$$, after market?
Old 07-30-2020, 07:19 AM
proporsche's Avatar
it is all up to you ..i`d if you can get good used-tested -..they do not go bad that often..
Ivan
Old 07-30-2020, 08:26 AM
Might check your firing order again since you did replace your cap. You won't believe how many times I crossed my wires up as careful as I tried.
Old 07-30-2020, 04:15 PM
I have screwed up my plug wires and it’s usually pretty obvious backfiring out of both ends!!
Old 07-30-2020, 05:07 PM
Took the unit off again for anther cleaning and tap (banging). Reinstalled and to my surprise its now working. Buzzing like a bee and the idle is smooth,
Thanks for all the suggestions.
Old 07-31-2020, 10:45 AM
proporsche's Avatar
great ..congrats..isn`t great to be persistent;-)
Ivan
Old 07-31-2020, 11:04 AM
