Rear oil tank loose wire
Found a disconnected wire on the rear oil tank under the pass side wheel well...did not notice any problems due to the disconnected wire. Maybe Im missing something?
Should a gauge or warning light be affected by this being disconnected?
Old 08-03-2020, 07:11 PM
Believe that's connect (sender?) to the oil level gauge in the car...
Most don't work properly...mine is pegged, I'm to lazy to replace the sender..
Old 08-03-2020, 07:14 PM
That gauge works well and didn’t seem to have been affected. That’s why I’m a little confused to what the wire was connected to.
Old 08-03-2020, 07:53 PM
Those are the only line ran to the tank...
I would clean that area up and see where its suppose to be connected...
Still pretty sure it goes to the oil level gauge..( not oil pressure)
Old 08-03-2020, 08:07 PM
dtwa's Avatar
That's the ground wire to complete the circuit to the oil level gauge. The other wire to the left (black if I recall) is the signal wire. Gauge may still work if the level sensor and gauge are both grounded to the body. The level sensor is attached to the tank, which is hard-mounted to the body (no rubber cushions), so there is a likely path to ground, but the wire makes it certain.
If that is oil (hard to tell), you need a new gasket on the level sensor. Pretty straightforward to R&R.
--Dave
1985 Carrera 3.2 • Prussian Blue Metallic
Old 08-03-2020, 09:12 PM
Walt Fricke's Avatar
If you lift the oil level sensor signal wire, your dash gauge will peg. If there is a break in the winding on the sensor (basically a rheostat), when the slider gets it will peg (so might work in the morning when a lot of oil has drained into the engine sump, but not after you get going and the level in the tank drops, with some flickering in between unless I have this backward).
My diagrams show a white ground wire, but Dave is right. Easy to check if this one is a ground, and hook it up. But no particular need to do so, since your gauge is working correctly.
Old 08-03-2020, 10:39 PM
Racer
winders's Avatar
Most DO work properly. Oil pressure is kind of important for an oil-cooled engine. If yours is not working, it would be a good idea to fix it.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 08-03-2020, 10:50 PM
WAS NOT TALKING ABOUT PRESSURE GUAGE...but oil level gauge....
Old 08-04-2020, 04:01 AM
Oil level gauge works too!
Old 08-04-2020, 07:01 AM
Racer
winders's Avatar
NOR WAS I!!
Oil level is important because if you don’t have enough oil you are going to have problem with oil pressure as the oil level gets way too low.
Scott Winders
PCA GT3 #3
Old 08-04-2020, 08:07 AM
IT IS THE GROUND WIRE!
Sorry for yelling
Old 08-04-2020, 10:46 AM
Visit a DIY car wash and remove that road grit and oil from the underside. Could be hiding corrosion. In addition, it looks awful. Inspect and repair. MHO.
Sherwood
Old 08-04-2020, 04:34 PM
Brown wires are grounds on early 911s. Just sayin’
1973 911 S Ivory White, 5sp MT
2023 Macan GTS Gentian Blue, 7 sp PDK
Old 08-04-2020, 07:06 PM
Just changed my sending unit. Easy to do.
Old 08-04-2020, 07:37 PM
Something is leaking somewhere. Take the tank down & have it cleaned & pressure checked (or do it yourself). As I recall, the tank hanger bolts (2) have a series of spacers/insulators to mount properly & they're always boogered up and/or installed wrong. Replace the dust shield, tank to inner fender well, replace the sending unit gasket, then route the wiring properly.
Shouldn't cost much for spacer/insulators and a gasket.
Old 08-04-2020, 09:19 PM
