Source for heater hoses
I recently completed the backdating of my engine compartment with older engine sheet metal and replacement diffusers off the fan. I really like the clean look. The hoses I used for the ducts to SSI's is the only dissapointment. I would really like to use some high heat silicone hosing, around 2.5" ID. I've checked the web and I get lots of tuner type places that don't answer their phone. I know they make a brown corrugated tubing also, but I was interested is something dressier and more rugged. The silver tubing shown lasted one DE weekend before is disintergrated. Thanks.
There is a company in Washington state that manufactures high heat/high pressure composite hoses called Belair Composites. They answer the phone, and can supply you with a custom hose set that will last. Their website is also pretty helpful. I am using them to supply the high pressure hosing from my turbos to the intercoolers.
Rick '78 930 |
89911 saw your car at the mechanics a couple of weeks ago, hthey had it in the showroom and i admired it while they put new tires on mine, that car is very nice.
gary
1975 911S Targa Silver Anniversary Edition |
Limbo
89911,
Would you want something like these?
Big ol built Duramax Durango R/T 19’ Current Custom project V8 M3 08’ Built and spoiled |
What material are those made of? It looks more durable then the aluminum hoses that are pictured. The material I wanted was similar to the silicone that connects the end of the heater box to the flapper assembly from the factory. If I went with silicone, would a need a straight piece of one with a preformed bend? I'm not sure how flexible that stuff is.
Gary, thanks for the compliment. My car sat there for more then a month. I wasn't in any hurry to get it out until the weather broke. Great guys. Pete is a very good mechanic. I just got it back with the newly painted and mounted Fuchs and I love the look.
Try Aircraftspruce and specialty co. ...they have SCAT / SCEET and host of other silicone tubing in various diameters. Single or double layer...all kinds. I bought from them for the exact same purpose. High quality stuff, red/orange for the version I bought much like pro's use for front brake work ducting on race cars. I'll try to dig up the web address if someone else doesn't chime in.
---Wil Ferch
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Thanks Will! Did you go with a straight piece?
Friend of Warren
89911, two questions, first, do you still get a fair amount of heat in the cabin using the footwell blowers or did you remove those also? Second, what is that gauge on the #1 intake runner?
Kurt V No more Porsches, but a revolving number of motorcycles. |
Schleprock
That certainly looks much cleaner than the big honking plastic plenum and blower motor.
Do the snorkels that come off of the fan housing simply replace the plastic plenum and block-off plate? So all you need is the snorkels and the rear sheet metal piece (or do you need the two side sheet metal pieces too)? I also was going to suggest Aircraft Spruce. Request their free catalog. There's all sorts of cool stuff in there that may come in handy someday.
Kevin L '86 Carrera "Larry" |
Schleprock
Kurt,
I was able to get heat from my B&B headers without the assist of the main engine fan or the assist motor in the engine compartment. I didn't have the crossover tube on the heat exchangers installed as shown in this picture: http://hstrial-klehmann.homestead.com/files/MVC_896S.JPG The only thing I had connected was the tubing that goes from the exchangers to the heater valves. Got pretty good heat. I'm sure the assist motors in the footwells had something to do with that.
Kurt, the heat is good. Sometimes a little too much at high rpm but still functional. The gauge pictured is a fuel pressure one that is attached to the fuel rail. I have an adjustable fuel pressure regulator and a MAF that needs adjustments for for maximum HP.
Bump
Vance '83 SC Cabriolet - The "Matrix" '73 914 - "Spicy Mustard" - SOLD |
Schleprock
Thanks Michael.
Hey, if your car was kept in the showroom while in for service??? Wow. That's gotta be one outstanding car you've got there.
Ordered 8' of an orange silicone 2.5" hose used for aircraft heating. Only $5.00/foot! Great deal compared to the stuff I was looking at the was costing $4.00/inch!! Thanks again.
answering 89911:
I bought a big straight piece as we were sharing the hose for a number of projects. I needed a small length to jumper the heat exchangers with the heater valves, and my colleugue needed longer lengths to connect all manner of heat tubing for his SSI's....great stuff, copper-coated wire with silicone body, can "bend" 180 degrees back onto itself quite easily, at least for the 2.5" ( ?) stuff we bought. ---Wil Ferch
Schleprock
Which type did you fellas choose? SCAT, SCEET,.......?
Check out this site. They have multiple silicon and specialty hose connectors in different colors.
info@belaircomposites.com Rick '78 930 |
89911,
I have the same massflow set-up installed and a new fuel pressure regulator not installed. What is your take on the whole Huntley system? Will I notice a difference once the fuel pressure regulator is installed? I love the look of your engine without the big blower assembly and would like to do the same. was there anything tricky involved with your blower removal?
Chris Johnson 87' 3.4 Carrera 73' 911t restoration project |
