ausgezeichnet's Avatar
Turn Signal Switch Connectors
Replaced the turn signal switch in my 83Sc. Before I started I had no hi-beams but turn signals worked. After the install I now have hi-beams but no turn signals. I checked and double checked the 4 wires were installed in the correct positions on the headlight switch. However I have two white plastic connectors ( between the back wires in the picture), one male and one female with nothing to connect them to. The two between the black wires in the picture. The male wire is black with a white and green stripe. The female connector is a solid gray. Any idea of what to do with these connectors?
Old 08-06-2020, 05:26 PM
proporsche's Avatar
looks like nobody pitched in yet or here you go..you have to find the black and gren opposite wire same goes for the grey wire look at this picture from my 911..
Mind you if you are using new switch i has the white cover-connectors but the wiring has black cover
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 08-08-2020, 07:10 AM
Thank you! I saw the black connectors but I thought they were for something else because they did not have the same white connectors.
Old 08-08-2020, 07:52 AM
proporsche's Avatar
u r very welcome;-)
Ivan
Old 08-08-2020, 09:36 AM
