drag racing the short bus
dd74's Avatar
Glasspacks and SSIs or heat exchangers
I posted this on Rennlist, but haven't gotten an answer: has anyone done or thought of mounting Glasspack mufflers to heat exchangers or SSIs? The Glasspacks need flanges welded onto them, but otherwise, look like they might work well.
I was looking at the Dynomax Thrush 24 1/2-inch, 2 1/2-inch diameter Glasspack.
Because of their straight through design, would they most likely inhibit low-end torque and increase high-end power as do megaphones?
Thanks.
The Terror of Tiny Town
Old 04-18-2003, 03:18 PM
Wouldn't the basic problem be their length and how to support them, or are you thinking of doing some fabricating and putting some 90-degree elbows in there so the Glasspaks run laterally?
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 04-18-2003, 03:23 PM
I would think the only problem would be they would be a little loud.
Go for it and let us know
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 04-18-2003, 03:30 PM
Navin Johnson
TimT's Avatar
try these, you will have to modify or remove the rear valence though.
buy them here
'69 911 GT-5
'75 914 GT-3
and others
Old 04-18-2003, 03:35 PM
marcesq's Avatar
Hmmmmmmm I haven't thought about Thrush mufflers since my '69 Firebird was banned from my parent's nieghborhood They were loudddd, and that was at idle.
'94 CMC Firebird Trans Am
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone but not forgotten.
http://www.pelicanparts.com/MotorCity/marcesq1
http://www.youtube.com/user/958Fan#p/u
Old 04-18-2003, 03:42 PM
RETIRED
Joe Bob's Avatar
Supertrapps....at least if you get busted by the sound police, you can remove some baffles to quiet it down for awhile....add one a week until you back to where you started.....
2012 ML350 3.0 Turbo Diesel
Old 04-18-2003, 03:47 PM
dd74's Avatar
steve: I haven't thought of how they would mount. For $17 or so from Summit Racing, I figure I don't have anything to lose, and can figure all that out when I get them - "them" being 2 of course.
MikeZ: I thought about Supertrapps, but seeing how large they are, I would think by image alone, they'd overpower the rear of my little narrow car.
NOTE: I'm still concerned about low-end torque and high-end power. Any insights from you guys about that?
Thanks.
Old 04-18-2003, 05:17 PM
RETIRED
Joe Bob's Avatar
I have the largest they make....3.6 needed them. They make many smaller sizes. Check out Summit Racing.
Old 04-18-2003, 05:21 PM
The Unsettler
stomachmonkey's Avatar
Funny, I was just looking at this today.
Holley makes a line of stuff under the Flowtech brand that might work. Summit sells it.
Check out the Purple Hornies. I'd buy em just for the name.
http://www.holley.com/HiOctn/ProdLine/Products/ES/ESFT/Muffler.html
Scoot
"I want my two dollars"
"Brandon Won"
Old 04-18-2003, 05:31 PM
dd74's Avatar
Scoot
Yeah:
The purple hornies might be a better bet since they have the flanges for the heat exchangers.
Old 04-18-2003, 05:33 PM
dd74's Avatar
I looked at the disc-only mufflers with the idea they could be adapted to megaphones, but they seem too large. Fact is, I don't even know if they can be adapted to megaphones.
Does anyone know the outlet diameter of megaphones?
Thanks.
Old 04-18-2003, 06:33 PM
Bill Verburg's Avatar
I have previously recommended the Coast mufflers that Tim referenced. They are light, rebuildable, efficient and absolutuly the best sounding 911 muffler I have ever heard, bar none. They are quieter than my Flowmaster/Fabiani.
I first heard them on this RSR
Where they come straight back off the header, but they could also be mounted in a parallel pair, transversely ala stock muffs
Bill Verburg
Old 04-19-2003, 06:35 AM
I'd go with just about anything before I went with a glass pack.
I have read several articles in various hot rod magazines in the past that said they were detrimental(sp) to power.
Besides, you get what you pay for.
I completely understand wanting to do something and being on a budget.
Old 04-19-2003, 08:03 AM
RETIRED
Joe Bob's Avatar
Those purple things look too much like what Billy Bob would put on the old Camaro.....
Old 04-19-2003, 09:21 AM
IROC's Avatar
I added a glass pack onto the end of the factory pre-muffler one time just to get myself to a DE before I could get my headers installed. It worked, but it wasn't anything to brag about. No performance gain, but surprisingly it sounded pretty similar to a factory muffler.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 04-19-2003, 09:41 AM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
I don't need no stinkin muffler!
Stock 993 Cat...2.5" pipes!!!
I also have quick video to show the sound, I posted it last week.
http://bender.annenberg.edu/pelican/new99304.AVI
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 04-19-2003, 10:02 AM
RETIRED
Joe Bob's Avatar
Dude.....do you have access to a decible meter? I would be interested in how that set up worked sound level wise......50 feet away, dbA level, not C and at 6,000 rpms......
That's how they test it here at the sound stations on the track....
Old 04-19-2003, 10:06 AM
Montana 911
k9handler's Avatar
I don't have access to the meter. I could say it's a little louder than my buddies Mustang GT (I love the GT sound) at idle...and as you go through the rpm range it gets loud! If I ride around at 2800 rpm it's very nice and the tone is perfect...on the other hand at 5000 rpm it's no doubt quite loud and everyone knows I am coming...and their eardrums burst and bleed if I pass them with their windows down! Ha Ha
H.D. Smith
2020 Yamaha YFZ450R
Old 04-19-2003, 10:29 AM
dd74's Avatar
K9 - I just listened to your sound clip - very sweet indeed. How's your drivetrain and suspension holding up with the 3.6? Is it so far able to handle all the new power?
Exhaust sounds good too. Why don't you run it with just straightpipes - no cats?
Old 04-19-2003, 11:47 AM
Early_S_Man's Avatar
Porsche Crest
The thing that most of the people installing glasspacks, or Supertrapps ignore [or are unaware of] is the need for a crossover pipe [or 'H-pipe'] to be installed ahead of the two 'straight' mufflers... to improve bottom-end torque!!!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 04-19-2003, 12:46 PM
