source for 87 911 updated rear AC condenser
Anyone know of a source of a parallel flow condenser which is drop in for 87 era cars?
anyone know who would make them for us? The rear condenser is easy to get to and reportedly 4 row parallel flow condensers are 40% more efficient that tube and fin. |
I purchased one as part of a kit from Rock at RetroAir in 2016 for my 87 Carrera. RetroAir is now part of Classic Auto Air and I'm not sure they still sell the parallel flow condenser.
RetroAir |
Rescuer of old cars
I'd be interested as well, if it was a true drop-in. All of the PF rear condensers I've seen have significant hose changes, with both inlet and outlet on the same end.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Uncertifiable!!!
Griffiths, good stuff!
https://griffiths.com/ Site is nice and direct. Great exlanations. You can buy direct or from our host. Cheers, Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
RetroAir Rear Parallel Flow Condenser
The RetroAir rear condenser is a true drop in. For my system I used a mixture of RetroAir and Griffiths parts. Griffiths has the best instructions and quality parts. The RetroAir are good but just slightly below Griffiths.
Here are photos of the RetroAir rear parallel flow condenser. ![]() ![]()
Rescuer of old cars
Harold, did you use Griffith's hoses with the RetroAir condenser?
Yes, I did use Griffiths' hoses since they are full size barrier hoses and fit the factory hose clamps.
Rescuer of old cars
Good. My '72 coupe had factory A/C, my plan was to use Griffith's hoses, evaporator, compressor and PF front condenser. My original rear condenser is corroded, so I need to replace it as well. I was going to just go with an OE type with all the rest of Griffith's stuff. But if I can just get a separate PF rear condenser like yours from ClassicAutoAir (new parent company for RetroAire products), I'll do that instead of OE. With both PF condensers and Griffith's better evaporator, should give good results.
I don't see any separate listings for the condenser only on their site, will need to contact them for a quote.
You should get very good results with that system. In 105F heat I have a 55F vent temperature with RetroAir PF rear condenser, Griffiths second gen front condenser (not PF) and Griffiths evaporator. Fan wise I'm using RetroAir's aftermarket front condenser and evaporator fans. The front condenser fan is good but I can't recommend the evaporator fan. It's using a hose clamp to hold the motor and twice now the motor has slipped enough that the fan is rubbing the evaporator.
Interesting. I've done two evaporator conversions on two cars without issue. Maybe the clamps aren't not tight enough? Maybe use some epoxy to glue the motor to the mount as well?
I've tightened the clamp once already and used a glue (don't remember which one) to try and fix this. It's not only that the clamp loosened but the way the fan is attached to the housing. To tighten the hose clamp, I needed to drill a hole in the housing. Then if I want to change the clamp the housing will have to be cut open. It's not setup for easy maintenance. I'm considered finding an early evaporator housing so I can mount the Griffiths Hurricane Evaporator Motor. |
Can you just buy the back condenser?
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
You might want to try adding the two add'l condensers in the wheel well. It's the key as greater heat dissipation from more condenser area means lower output temperatures. Good luck!
2002 GMC Yukon SLE - 4AT - Purchased New in 2002 1988 911 Cab - 5MT - Purchased Used in 2005 2008 Cayman - 5MT - Purchased New in 2007 2014 911/50 - #1173 - 7MT - Purchased CPO in 2014 2019 Macan S - 7PDK - Euro Delivery/New in July 2019 |
I'm very happy with my vent temperatures. My wife has spoken the best of the AC system since updating it. She said "I'm cold!"
This is actually my second Griffiths system the first was a 911SC which I had in Malaysia. That car had the full Griffiths system evaporator, front condenser and dual condensers in the left rear wheel well with fans (front and behind wheel). For my US Carrera, I decided to use the RetroAir rear engine lid condenser instead of the additional condensers Griffiths offers. |
So Retro Air had a condenser that was drop in from the pictures.Anyone know much about the company Rock sold to- Classic auto air? I went to their office/warehouse 2? yrs ago, not too long after buying out Rock at Retro Air. very disorganized-they could not even show me the parts and had no knowledgeable people. As I remember the rear condenser had both ports on same side and not drop in- part of a kit? The website now does not work at all. May be able to call and see. It seems many sites want to do 1960s US cars. Hopefully they will sell parts separately. Generic parallel flow condensers are in $100-200 range so we should make some
Rescuer of old cars
The condenser they show with their kit has both ports same side, which is why I hadn't thought there was a PF drop-in replacement. I hope they still have the standalone part, but after trying to find ANY condensers with fittings on opposite ends on their website, I'm not optimistic.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 Last edited by Arne2; 08-21-2020 at 07:28 PM.. |
![]() Having both hoses attached at one end didn't cause any issues - just need a longer hose! Rock supplied some simple brackets to mount it up that could be reasonably easily made yourself. As for the evaporator it appears to be just a generic one that has been curved over a former. I've never bent a evaporator before but imagine it wouldn't take too much effort. Last edited by Peter M; 08-22-2020 at 03:07 PM.. |
Harold, I suspect your fan is out of balance and this is causing the motor to vibrate and to shift in it's mount over time. |
Thanks Peter for the insight.
Peter M
Does your system have any more modifications than a better rear condenser? Was routing the longer hose a problem? |
