The ultimate brake upgrade page.
Since so many are asking about brake upgrades, I thought I'll post some of the previous threads that I've collected during my research. There must be others and I welcome you to post them here.
If you are one of the lucky guys that already have modified your car please post your input on how, what you have used and problems encountered. Pictures says more than a 1000 words. Here some: http://www.pelicanparts.com/MotorCity/wmv/ Bill Verburg's Pelican Web Site 944T calipers on my 911 944T calipers on my 911 930 rotors w/ big silver-fvd spacer needs washers? 930 rotors w/ big silver-fvd spacer rear 944T brake install on my 76,question. rear 944T brake install on my Question for the brake pro ! Question for the brake pro ! 996+993+964+3.3T+944T brake spec. 996+993+964+3.3T+944T brake spec. Brake hardware and what is this mecedes M/c that works with big brakes? Brake hardware and what is this mecedes M/c that works with big brakes? 996 monoblocks on SC 996 monoblocks on SC Rear brakes? Rear brakes? Thinking About Drilled Rotors? Thinking About Drilled Rotors? RS92 brakes on SC RS92 brakes on SC Late 930 Hubs on a 911 Late 930 Hubs on a 911 http://www.rennsportsystems.com/~porsche/1-sf.html Rennsport Systems http://www.vehiclecraft.com/Brakes/930T_mod.htm VCI http://www.instant-g.com/Products/BigRed/index.html instant-G If you have comments to your old thread please post your comment in that thread so it's updated. New inputs and links are welcome here. Here some of the pics I like: Bigred on 322*32 and turned hubs '81-'89 930 304*32 rotor/hub vs 911 282*24 kit sold on ebay: 928S4 on 304*32 and 966TT on 330*28![]() Caliper machined and axial/radial adapter installed Big red installed at rear
You might not be happier owning a Porsche, but it certainly feels so driving one |
Cool, thanks for compiling so many sources.
I've long thought that the archieves should be organized some how. All it takes is someone w/ some energy. Keep going, there are a ton more.
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 04-23-2004 at 01:12 PM.. |
Great job Palle!!!
Warren & Ron, may you rest in Peace. |
A nice addition would be cooling ducts. Here are some.
Brake Cooling Hose Manifolds Brake Cooling Hose Manifolds Project little reds Project little reds Project little red, part deux Project little red, part deux
More brake upgrade:
930/944T brakes on SC/Carrera 930/944T brakes on SC/Carrera http://vintagebus.com/howto/brakes/front/ Installation of 930 front brakes on a 911 http://vintagebus.com/howto/brakes/rear/ Installation of 930 rear brakes on a 911 944 turbo brake upgrade 944 turbo brake upgrade 930 calipers (used) - worth buying for an '86? how much? 930 calipers (used) - worth buying for an '86? how much? Boxster Brake Upgrade for Carreras Boxster Brake Upgrade for Carreras http://tech.rennlist.com/911/pdf/Upgrading_Porsche_Brakes.pdf http://tech.rennlist.com/911/pdf/911brakecaliperoptions.PDF 930 brakes on Carrera??? 930 brakes on Carrera??? Good luck with reading all this
One of the better front setups
993RS/993tt one of the better rear setups 993RS/993tt Next step down 993 Next step down 964/944 Next step down 930 ![]()
BIG step up:
15" rotor w/ 8 piston (radial mount) caliper.
Yes it is! But as far as I know unavailable for 911 use
Its true that the 15" (380MM) brakes are not available for 911's, but a 355mm front brake kit is available for '80-'89 Turbos,....
![]() These use a larger piston version of the Big Red caliper and it matches well with the 993 Carrera RS rear caliper.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Is that the EVO kit w/ the genaric Brembo 40/44?
How about some notes on brake pedal feel with some of these updates.
My nephew recently did the Big Red update on his 993 and the pedal feel in use doesn't come close to the stock feel. It brakes great(did fine stock also!) just doesn't have a reassuring feel to it. I hear this is a common complaint from 993's with Reds. |
89turbocabmike, check those threads and you will probably find the answer.
What master cylinder are you/your nephew using? With those calipers with big pistons displacing more fluid you will want 23 mm m/c.
At the back the stock 993 has the biggest generally available pistons at 30/34 only the 993RS are bigger at 30/36. So unless the change included 993RS rears the pedal can only get higher and firmer w/ a change there. The cars that have an issue w/ pedal feel are the 964s. When upgrading their calipers a 993 m/c should be used.
89turbocabmike, I just reread your post, didn't realize it was a upgrade on a 993.
Thanks Bill and Palle, I'll mention this to my nephew. A few 993 Rennlisters we drive with complained of the same pedal feel, perhaps this is a brake bleed problem? One in particular is a C4s which I understand are more difficult to bleed.
Thought I'd add some links;
How To Calculate Brake Bias Boxster Front Caliper Upgrade 1 Boxster Front Caliper Upgrade 2
Chris - - - - - - - - - - - - - - - - - - - - - 1982 911 SC Hellblau Metalic - - - - - - - - - - - - - - - - - - - - - 1997 Boxster 986 2.5l |
Thanks Glasgow, good threads.
My 83sc, ex GT2 disks and calipers........
380 x 32 fronts 322 x 28 rears custom pedal box with 2x 0.625" m/c for adjustable bias ![]() Braking is err.... ample!
Just because YOU think it's a stupid idea, won't stop me from trying it! ------------------------------------------- '83 Porsche 911SC -project moneypit '89 BMW 325i touring - 300hp tow car |
jph83
Is your car up & running? Been looking forward to seeing the finished article since the 1st pics you posted here.
