Question 2.7 knocking at low RPM?
At around 1,100 rpm (when warm) there is an noticeable knock. Oil pressure gauge is reading below 20 at idle when engine is warm.
Could this be caused by a low oil level?
With a dry sump system is it possible for a low oil condition to cause this?
I have yet to do more diagnostics to try to isolate it to a particular jug. John Walker mentioned the left side tensioner/ chain was noisy...
71 911T
75 911S
Old 06-22-2016, 04:34 PM
by knock, do you mean detonation? if so oil level probably isnt a contributing factor. could be a lean mixture, timing out of spec.
if you dont mean detonation, that could be serious
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 06-22-2016, 06:45 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Video it and post.
+1, Lean Mixture or Timing issue.
Sounds are subjective so a video could help clear your potential issue.
'85 Carrera Targa
PCA/POC
Old 06-22-2016, 11:39 PM
You can clearly hear the knock at :34 and again at 1:30.
https://youtu.be/qPYmhKjM_i8
71 911T
75 911S
Old 06-30-2016, 05:04 PM
Under the radar
Trackrash's Avatar
It sounds to me like one cylinder is limping or missing. Fouled plug?
I don't hear any "knocking" per se. There is a valve ticking, but nothing bad.
What do the plugs look like?
You should get a stethoscope and see if you can isolate the source.
Gordon
'71 911 Coupe 3,0L outlawed
Old 06-30-2016, 06:10 PM
Sounds like a wrist pin knock to me.
Old 07-01-2016, 05:10 AM
T77911S's Avatar
yea I heard what you are talking about.
the valves are a higher pitched sound, the other sound is a low pitched knock. I have heard it on other cars but don't know what it would be,
I would go thru the valves, check the lobes, check the head studs.
go ahead a doa compression check just to see where it is.
then take another listen.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 07-01-2016, 06:25 AM
You have no oil pressure. The needle doesn't even move when you rev it.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 07-01-2016, 09:32 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
You're in John Walker's area. Maybe stop by his shop and get an expert opinion?
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 07-01-2016, 12:35 PM
Tow it to the shop
Old 07-01-2016, 02:24 PM
True. I think the oil pressure sender needs replacing. I didn't want to pull the motor to do it.
The knock doesn't sound like a rod bearing. I'll ask Walker.
Jeff H did the motor not that long ago. Walker did a valve ajust not more than 300 miles ago......................
This car has been bad luck the whole time I have owned it. Someone make me an offer. seriously, I want a 964!
71 911T
75 911S
Old 07-01-2016, 08:57 PM
analogmike's Avatar
I am having the same issue on my freshly rebuilt (about 3 races old) 2.7RS engine.
At low idle, it will occasionally knock pretty loudly with the oil pressure dropping.
No noises at higher RPMS. Speedsport tuning got it running well but could not find the problem without opening the engine.
I have a big vintage race at Lime Rock in under two weeks, afraid of running it like this.
Did you find out what your problem was?
Regards, Mike. AnalogMike at aol dot com
'73 911RS Clone, '08 911 GT3 cup,'04 Touareg, '16 Audi S3, '01 Viper GTS,'05 Bentley CGT, '50 Crosley Hot shot
my racing pages - http://www.analogman.com/911
~^v^~ aNaLoG.MaN ~^v^~ guitar effects LLC www.analogman.com
Old 08-27-2020, 10:40 AM
Under the radar
Trackrash's Avatar
I had a similar issue. I would recommend using a stethoscope to isolate the noise.
You may want to post a video with good sound. Maybe someone would have an idea of the source.
Here is my thread. Knocking noise in motor?
Gordon
Old 08-27-2020, 05:30 PM
Gordon, did you resolve your issue? Ignore it?
These threads make me wonder if I'm hearing things on my car after!
Old 08-27-2020, 05:49 PM
Under the radar
Trackrash's Avatar
It is coming from the right side chain idler on my motor. When I opened up the chain cover I could make what sounded like the knocking noise by moving the idler pulley back and forth on the shaft. Seemed to be quite a bit of side play. It isn't doing it as much any more and isn't noticeable when warmed up. I have over 6K miles on the motor. My guess is the idler pulley is just rattling back and forth at a certain RPM.
Listen to the video I posted and compare my sound to yours.
Gordon
Old 08-27-2020, 06:22 PM
Mike,
I would install a mechanical gauge to confirm the oil pressure. You may want to install the later cam oil line restrictors. This should increase your idle pressure.
Old 08-27-2020, 06:36 PM
proporsche's Avatar
Mike ;;make a video ..it will help us to locate your sound better
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 08-28-2020, 12:42 AM
analogmike's Avatar
Ivan
It's a loud slow mechanical knock, I thought it was from the chain housing but I ran it with the cover off and all fine in there. I can't confirm the pressure issue (SST mentioned it and they used a VERY expensive accurate mechanical guage).
The knock occurs more frequently when the engine warms up and the idle goes down. Runs perfect at fast idle or up to redline.
Here are some videos:
https://www.youtube.com/watch?v=hGRFJu6Ad40
https://www.youtube.com/watch?v=hiF2EEQxYRU
I wish it were easier to access the clutch and flywheel, that's another possibility.
Old 08-28-2020, 12:01 PM
Flywheel is loose.
It's not a rhythmic knock like something internal.
Old 08-28-2020, 05:38 PM
analogmike's Avatar
Could be flywheel, I will listen carefully in that area tomorrow and pull the trans if I think that might be it. thanks!
Old 08-28-2020, 06:20 PM
