Follow these instructions (yelcab’s).......
To OP, A version of the above instruction: If you have two (2) sets of dial indicators, it would be much easier. Set it @TDC @Z1, for cylinder #1 and turn the crankshaft 360°. Read the dial indicator. You are done now for cylinder #1. Move the dial indicator to cylinder #4: Reset to zero and turn the crankshaft another 360° (back again to TDC @Z1). Read the dial indicator. Repeat again and get an average. You are not alone. Even the experienced individual commits same mistake/s. Tony |
Update:
Took timing cover off the right side along with upper valve covers. Both banks were definitely timed the exact same. I moved the crank to TDC on cylinder 1, with the intention of then loosening the right bank's cam bolt and rotating the crank 360 degrees. While the #4 intake valve was closed, I set up my indicator to measure lift. I loosened all the valve adjuster nuts to max - rotated 360 degrees, pinned the cam adjuster/quarter tightened the cam bolt, and remeasured the timing. It was still in spec at ~1.6mm. Adjusted valves and buttoned everything up. Car started immediately! It also cranks much, much faster now that starter isn't trying to push through 2 cylinders in their compression cycle. Thank you for everyone's help! - Ian |
Imagine no bent valves !!!
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Only the most die-hard of enthusiastic DIYers would have ... two sets of indicators and 2 z-blocks.
Whew, nice conclusion!
No. Cam 180 out is crank 360 out. Perfect timing except both sides are trying to fire at the same time.
72 Carrera RS replica, Spec 911 racer |
Stomski tools.........
Yel, There are no z-blocks in my tool box anymore. A switch has been made some years ago to these: ![]() ![]() ![]() You don’t need these fancy tools to do a good job for your engine rebuild projects. I’ve been using home-made tools from Home Depot, Lowe’s, and Harbor Freight rebuilding more than a dozen engines before owning my first Stomski tool. You would think that these tools are expensive and extravagant to possess but wait till you use them. Your perception would change. I am cheap and frugal and only bought the wrenches I needed to do the job from HF. Then one day, I decided to replace my home-made PVC cylinder hold down gadget with Stomski SR-007 and continued adding more. There is no substitute for good quality tools. Tony |
Like I said, only the die-hards have those tools. I do cam timing on Ferraris and Porsches all the time and I don't have those high end tools. I finally bought some digital calipers and dial indicators because of the "zero" features. The math was too hard on analog scales. I also bought a fully articulating mounting arm with a single tightener and it really was a game changer.
Still, I can't see myself with that Stormsky set up. Maybe if I do a 911 once a week... I do have 12 torque wrenches....
great that you found the problem
those stomski's are nice i have the exhaust stud tool but have not splurged on the others yet.
1975 911S Targa Silver Anniversary Edition |
Thread Tools | |
Rate This Thread | |
