Have a 1985 911 with center console?
I reinstalled my console which includes a temp control switch, fan control and red door lock button at the top of console.
If you have an 84, 85 or 86 with the same console please tell me what is illuminated on console when you turn the lights on....photo below...
Do the knows on the TEmp Switch and fan control illuminate?
The red Door lock IS NOT lighting up.... but it does lock the doors. I recall the door lock button lighting up dim then very bright red once you locked the doors. What else is illuminated on console?
Old 08-24-2020, 06:04 PM
console 1985 911
do these illuminate?
Old 08-25-2020, 11:43 AM
proporsche's Avatar
no never unless you make it yourself..;-0
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 08-25-2020, 12:15 PM
Ctopher's Avatar
My 87 has different AC controls but I can say the door lock button should light up.
Old 08-25-2020, 12:45 PM
stopped lighting up
I did light up but once I disconnected it and re-connected it, it stopped. It works, locks the doors, but no longer lights up. Hate to spend $130 on a new one just for the light!!
Old 08-25-2020, 12:48 PM
On my 1985, only the door lock button is illuminated. It has a dim glow if the door are unlocked, and a brighter light if the doors are locked. The AC controls are not illuminated.
Old 08-25-2020, 12:52 PM
carreradpt's Avatar
Same here, 85 also.
Dan T
'85 Carrera
Dansk premuff/sport muffler
7's and 8's, Steve W chip
Kuehl AC and fresh top end
Old 08-25-2020, 01:50 PM
Need this this bulb From center locking switch 85 911
Thank you gh85carrer, Carreradtp
Hoping I can find the bulb from the Crnter Locking Switch
Old 08-25-2020, 06:19 PM
The bulb has a soldered connection
Old 08-25-2020, 06:23 PM
OK, no doubt that bulb is blown.
Unsolder it, carefully and take it to a batter and bulb business. They have a drawer full of bulbs. Likely something of the right style. Worst case solder some wire leads to the side of the bulb and the base and solder in place.
Old 08-26-2020, 09:19 AM
when you say "IS ILLUMINATED", you do mean dimly lit ONLY when you turn the lights on and get brighter when you lock the doors?...
ALSO, Is it lit when your lights ARE NOT on?
Old 08-31-2020, 04:35 PM
Tags
console , door lock , interior lighting
