difficulty of throttle tension spring replacement
Looking to replace my throttle tension spring, how difficult? Anyone have a photo of its location...quick tutorial? 1985 911 Thanks
There are a total of 3 in the engine bay. Are you referring to the two underneath/close to the plenums?
Serge |
I may looking in the wrong place.. might need new throttle rod bushings. Do you know how I can access those?
Thanks |
A bit more working room if the heat blower fan is out of the way.
| Tags |
| idle , pedal , throttle tention spring |
