Window issue
I have a 1985 911 Cabriolet, the passenger windo operates form both switches, the mirrors work, but the driver side window does not. Is this a relay issue as the harness seem to be good
Try switching out switches from passenger side to drivers side..
Agfours
Be sure you have the wires going to the right spades on the back of the driver side switch. There are wiring diagrams and pictures of wire colors folks have posted. Helps to have a multi-meter and check the switch per the diagram at each pin. My bet is that one (two) of the wires are in the wrong place on the driver's switch.
Paul Present and accounted for: 1986 Carrera Coupe, 2021 Audi SQ8...Gone but not forgotten: 1987 Carrera Coupe, 1996 911 Carrera C4S, 1985 911 Carrera Cabriolet M491, 2011 Cayenne Turbo, 2001 Boxster S....Me: "What is your return policy?" FLAPS rep: "We really expect you to keep it..." |
Agfours
Here's a link to a thread with pictures of the pin-out for each switch...
https://forums.pelicanparts.com/porsche-911-technical-forum/957564-passenger-power-window-problem.html
Vintage Owner
Window switches
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
