Front AC Condensor Fan
Hi everyone, I was hoping for some of the forum expertise here. I have a 1986 Porsche 911. Everything seems to be working just fine, except for the front condenser fan.
Here's what I've done: - I have turned the car on, but not started. Set it to full evaporator fan speed and full cold on the thermostat. I can hear the evaporator fan come and it blows air, no problem there. I also have fans on my rear condenser connected to green wire on the compressor, and they kick on as well. - I tested the power at the plug to the front fan. It's showing roughly 11.5 volts. - I have a Zims adaptor with fuse in it. I plugged that in, still getting voltage through it. - I can apply power to the fan and it operates. - But, when I have it connected, it doesn't come on. Any recommendations? Thank you. |
Current draw from the fan may be too high indicating the fan motor may be on its last leg. Just replaced mine a few weeks ago. Those motors are still available and not too expensive at least not for my SC.
Walt 82SC 3.0 81SC 3.6 |
Any chance the front fan comes on with the compressor switching on?
2002 GMC Yukon SLE - 4AT - Purchased New in 2002 1988 911 Cab - 5MT - Purchased Used in 2005 2008 Cayman - 5MT - Purchased New in 2007 2014 911/50 - #1173 - 7MT - Purchased CPO in 2014 2019 Macan S - 7PDK - Euro Delivery/New in July 2019 |
Walt, I appreciate that input. I guess I may have to try a new motor, though when I apply power to it, it runs great.
Pavegeno, compressor is on, the fan does not come on. I did make sure the compressor was on. |
So you have 11.5 volts available but it only runs when you wire directly to the battery, so I think you may have a current issue thru your existing wiring. Remove and clean the AC fuse and check the condition of the wires leading to the fan.
Is this the type Zims adapter you used.
http://www.***********/store/front-condenser-fan-update-fuse-harness.html URL does not work.
Walt 82SC 3.0 81SC 3.6 Last edited by walt; 09-13-2020 at 04:27 AM.. |
+1 this. Your battery voltage is likely something like 12.6, so there is some resistance in the circuit as Walt says if it’s measuring 11.5 volts without the load of the motor.
1990 964 Coupe 1986 Carrera 3.2 Targa |
Pull the fan housing and the fan. You'll have to pull it anyway to replace it. Put power to it and spin it with your hand and see if starts working. Probably want to squirt some oil into the bearing on the motor. If it's not fried looking I bet it spins right up.
1973 911T Sepia Brown MFI 1986 Carrera Meteor Gray Metallic |
