ChrisP911's Avatar
Bitz racing MS2 efi
Has anyone installed the bitz racing MS2 efi kit using the EDIs unit. Just got my kit today.
Just looking for some feed back
Old 10-07-2020, 04:57 PM
E-85 sippin drunk
turbobrat930's Avatar
So, you bought an EFI kit, but are looking for feedback on said kit, after you bought it?? That should have been a question you asked before spending your hard earned cash!
Or, am I not understanding the question right, and you are looking for advice on how to install, wire, etc of this particular kit?
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 10-07-2020, 05:14 PM
ROW '78 911 Targa
timmy2's Avatar
I believe He is asking if anyone has experience/tips installing EDIS with the BITZ kit using MS2.
The Bitz kit is very straightforward for EFI fuel only.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 10-07-2020, 07:50 PM
I would rather be driving
jpnovak's Avatar
So are you converting the Bitz MS1 to a MS2 daugter board and adding ignition capability?
In the past ( I don't know the current situation) Tony would not completely install the components to drive ignition. You will need to carefully check your board to determine if these are all present for the circuitry needed to drive EDIS.
Additionally, there was no ignition output wire needed to drive the EDIS controller ignition input. You will need to check the harness and add the wire to the db37 connector.
This also means changes are required to get a 36-1 toothed wheel and VR pickup signal to the EDIS controller. The stock Bitz wiring schematic will require some changes to get the EDIS connected.
Now, once connected EDIS works great. And Tony has great base maps to get your fuel delivery started.
Old 10-07-2020, 08:34 PM
ROW '78 911 Targa
timmy2's Avatar
What does the label on the ECU say?
I see the writing on the big box says MS2 CPU, does that mean it is an MS2 unit or an MS1 with MS2 extra software installed.
Need more information on what you have.
Dennis
Old 10-07-2020, 08:59 PM
So, Tony has finally run out of MS1? I think they're still quite functional, but not many left if available.
Did the kit actually come from Bitz? - I see his special bungs for the injectors.
Old 10-07-2020, 10:30 PM
