Poor ride quality 75S
My new to me 75S suffers from what I consider a harsh ride. Small impacts such as expansion joints feels like the car sort of crashes over them with no compliance. Larger bumps don't seem to be any worse.
Suspension is totally refreshed with new rubber bushings everywhere and Bilstein HD's front/rear. Everything is stock including the ride height.
For comparison, my former 67S with Koni's and uprated suspension for autox was much more compliant. It had 21/26 torsion bars with 22mm sways and just didn't suffer from the "crashiness" I'm getting on the 75.
I've read threads on digressive valving for Bilsteins, or may consider trying Koni Red's all around. Not sure what else to do..
Current: 1975 911S --Chocolate brown
Past:
1967 911S --Bahama Yellow
1990 C2 Targa --Silver
1973 914 2.0 --Delphi Green
Old 10-05-2020, 09:41 AM
Behind the Sun
If you don't track it try street tires
Lower your tire pressure
That's how I deal with my car with polybronze and MCS all around
Old 10-05-2020, 10:24 AM
I'm running street tires now, Vredestein Sprint's. Tried another set of street's I have on different wheels, no change.
Past:
Old 10-05-2020, 10:56 AM
Probably someone put bigger torsion bars all around.
I had a 76 930 that had to run about or over 80 so the road seams didn’t seem like rumble strips
Bruce
Old 10-05-2020, 11:04 AM
ride quality
In my experience, shocks make more of a difference than torsion bars.
John
Old 10-05-2020, 11:19 AM
Bruce
Thought that too, but they're stock. I actually changed out the rears with adjustable spring plates and upped them to 26's. No difference in ride, but I'm going to do a bit of autox with it and like the combo of stock front with more rear bar, turns in better.
Anyhow, I'm going to take the front apart to make sure top mounts and such were installed correctly and rubber is in the correct places.
Past:
Old 10-05-2020, 11:45 AM
Under the radar
Trackrash's Avatar
This is a long shot, but I believe that year came with the raised suspension that used the doughnut spacers on top of the front shocks. Worth a look, I guess.
Gordon
'71 911 Coupe 3,0L outlawed
Old 10-05-2020, 11:50 AM
Thanks Gordon, I'll check that out.
Running 25psi in 70 series street tires shouldn't feel like this..
Past:
Old 10-05-2020, 12:38 PM
KNS KNS is offline
That should be down right "cushy".
Kurt
Old 10-05-2020, 02:31 PM
I think stock t-bars on a '75 is 19/23. I've got 21/26 on my '75 with digressive shocks and it's certainly "firm" but not "crashy".
Are you sure you've got some suspension travel and it's not just bottomed out somehow?
Old 10-05-2020, 08:35 PM
racer's Avatar
That's not stock USA ride height. Might be closer to Euro ride height.
Also agree that larger torsion bars dont necessarily contribute to "crashiness".. My SC ran 22/31 bars and was firm, but not crashy.
It does sound like a shock valving issue, alignment/caster or even bumpstop issue. I wondered if it is actually "too low" and limiting the shocks effectiveness. Or perhaps there has been a shock failure. Do you have an old receipt with alignment settings?
While it likely won't matter, I think stock tire pressures were staggered, likely 26F, 29R
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 10-06-2020, 05:03 AM
It was at stock ride height when I got it, lowered it to euro after a few months. It was just as harsh when higher.
I've changed Tbars on several 911's over the years, never really noticed much change in ride harshness, just less body roll really.
Guess I'll pull all the shocks and check things closely.
Past:
Old 10-06-2020, 06:54 AM
This sounds like alignment issues, same as i had after doing the full suspension. Not everyone understands how to align these cars. One trip to turn 3 who understood what was necessary and it is a different car.
Old 10-06-2020, 08:14 AM
Alignment isn’t going to affect ride quality. That’s typically a shock issue or a suspension stiction in rare cases.
My vote is shocks or possibly shock spacers if it has them.
Tony
Old 10-06-2020, 09:38 AM
I'll bet it is bump rubbers as trackrash said.
Mark the outer dust shield height on the inner tube at ride height .
Then undo the lower mount and compress the shock to the ride height mark , then measure how much more you can compress the shock until it hits bottom or the bump rubber .
I look for about 1.25- 1.5"
I usually have to cut off 1 or 2 doughnuts to get the right length for compression
Ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 10-06-2020, 10:02 AM
